Kamilos Moderátor
Zařízení: SG S9+, SG Gear S3 Frontier
Odesláno: 18. 07. 2011 19:48
3C Battery Monitor Widget Pro
Battery Monitor Widget Pro v1.7.1
(98,- Kc)
Popis: The most complete tool to manage your battery: Shows historical data (%, mA, mW, mV and temperature), calculates estimated run-times and battery aging, helps calibrate battery, and improves your battery run-time.
VIDEO
https://market.android.com/details?id=ccc71.bmw.pro
http://www.edisk.cz/stahni/21143/b171.apk_629.53KB.html
http://www.uloz.to/9719359/b171-apk
http://uploading.com/files/98fdc1e3/b171.apk/
http://ul.to/byoqot1b
http://www.filesonic.com/file/1463967754
Kamilos Moderátor
Odesláno: 09. 10. 2011 18:59
Battery Monitor Widget Pro v1.9.0
New unplugged statistics
Improved measured mA
Fix calibration before history is loaded
Phone time format in graph axis label
Smaller APK
http://www.edisk.cz/stahni/65856/b190.apk_881.35KB.html
http://www.uloz.to/10565729/b190-apk
http://turbobit.net/t25000198sy5.html
http://www.multiupload.com/AHN7BHFPCY
http://www.filesonic.cz/file/2463595214
http://www.wupload.com/file/350804115
http://www.megashare.com/3638839
ROB_09 Mobil Guru
Zařízení: SE wt19i
Odesláno: 12. 10. 2011 19:17
Battery Monitor Widget Pro v1.9.1
http://www.uloz.to/10603598/battery-monitor-widget-pro-v191-apk
http://www.edisk.cz/stahni/48574/Battery_Monitor_Widget_Pro_v191.apk_889.52KB.html
http://download.hellshare.cz/battery-monitor-widget-pro-v191-apk/3780106/
Naposledy upravil(a)
ROB_09 dne 31. 10. 2011 20:11, celkem upraveno 1 x.
Kamilos Moderátor
Odesláno: 26. 10. 2011 20:31
Battery Monitor Widget Pro v1.9.3
-Updated AdMob SDK for better stability
-Add option to move history to SD/internal memory
-Add maximum history size (truncate on app start)
-mA support for Disney Mobile phones
http://www.edisk.cz/stahni/79356/BatteryMonitorWidgetProv193-Market-Militia-.apk_903.39KB.html
http://www.uloz.to/10774993/batterymonitorwidgetprov193-market-militia-apk
http://www.multiupload.com/SA6BQ61ZJS
http://www.wupload.com/file/1137359556
http://www.megashare.com/3673035
Kamilos Moderátor
Odesláno: 28. 10. 2011 11:54
Battery Monitor Widget Pro v1.9.4
-Fix preferences on Ice Cream Sandwich (4.0)
-Fix SD/internal switch for some devices
http://www.edisk.cz/stahni/44841/BatteryMonitorWidgetProv194.apk_661.74KB.html
http://www.uloz.to/10791569/batterymonitorwidgetprov194-apk
http://www.multiupload.com/M8KMA3CYDS
http://www.megashare.com/3676697
http://www.filesonic.cz/file/2782004875
Kamilos Moderátor
Odesláno: 01. 11. 2011 12:11
Battery Monitor Widget Pro v1.9.5
- Ability to export live-data to System Tuner Pro
- Since unplugged statistics not reset after reboot
http://www.edisk.cz/stahni/72857/195BMWP-MM.apk_905.66KB.html
http://www.uloz.to/10840929/195bmwp-mm-apk
http://www.multiupload.com/BBJ42PW3QT
http://www.filesonic.cz/file/2853231965
http://www.filefat.com/nbcuzm2xrxzl
Kamilos Moderátor
Odesláno: 08. 11. 2011 12:59
Battery Monitor Widget Pro v1.9.6
New multi-battery comparison screen
Simplify calibration screen
http://www.filesonic.cz/file/3188588485
http://www.wupload.com/file/2002862322
http://www.megashare.com/3703376
Kamilos Moderátor
Odesláno: 17. 11. 2011 00:58
Battery Monitor Widget Pro v1.9.7
New stats for current/unplugged/charged times
Improve support for small screens (calibration)
Improve capacity calculation
Fix history truncation when setting no limit
http://www.edisk.cz/stahni/95648/b197.apk_911.72KB.html
http://www.uloz.to/11102972/b197-apk
http://www.multiupload.com/6MJ7BU7O01
http://www.filesonic.cz/file/3847404025
http://www.wupload.com/file/2328890356
http://www.megashare.com/3727465
Kamilos Moderátor
Odesláno: 18. 11. 2011 10:25
Battery Monitor Widget Pro v1.9.8
Fix first time capacity calculation
http://www.edisk.cz/stahni/34487/b198.apk_911.39KB.html
http://www.uloz.to/11128182/b198-apk
http://www.multiupload.com/AS534GGH02
http://www.filesonic.cz/file/3923653305
http://www.megashare.com/3730089
Kamilos Moderátor
Odesláno: 20. 11. 2011 13:09
Battery Monitor Widget Pro v1.9.9
Updated Italian translation
http://www.edisk.cz/stahni/71635/b199.apk_915.74KB.html
http://www.uloz.to/11170962/b199-apk
http://www.multiupload.com/QTJIE1D7D7
http://www.filesonic.com/file/3952944175
http://www.megashare.com/3735181
