Požadavky: Android 1.6+
Auto Sound Disabler is the killer app to turn off the ringing tone automatically when you're in places like libraries, hospitals, school or in your own work.
Configuration is very simple. When you connect to a wireless network, it automatically establishes network known and sound off whenever you are.
If you will not turn off when you are in that network, just remove it from your bookmarks, removing the star.
You can also manually choose which networks use to disable the tone phone. No need to have the router password!
Choose from vibrate or silent mode total.
WIDGET incorporates direct access to the activation and deactivation of the application.
SUPPORT In addition the following languages EN, DE, ZH, ES, JAP, FR, ZH-TW
https://play.google.com/store/apps/details?id=com.stkdevlopers.autosounddisabler.pro
http://www.MegaShare.com/4464071
http://uploadmirrors.com/download/13V1OWQW/Auto_Sound_Disabler_PRO_v1.1.apk
http://directmirror.com/files/GSRACVPA
