(29,- Kc)
Popis: Easily monitor battery level with large colored status bar numbers.
Low battery alert bug fix
https://play.google.com/store/apps/details?id=com.larryvgs.batterypro
http://uloz.to/xo2suGM/battery-notifier-pro-bt-v2-1-8-apk
http://www71.zippyshare.com/v/56936561/file.html
http://www.embedupload.com/?d=7INZRXITGG
* Roboto HD font in official Android colors included
* Brighter ArialXL-b HD font for dim Android 3.x/4.x status bars also included
* Optional black background for light status bars
* Numerous extra-large and brighter HD add-on fonts
* NEW - Charger connection alerts (Now both connected and disconnected options)
* NEW - Wireless charger support (Android 4.2 and up)
* Custom color options display colors you want at the levels you want!
(Also works with 12 HD add-ons and 3 legacy text add-ons)
"Fantastic app" "powerful battery manager" "clean and simple user interface" "easy-to-use" "definitely worth your time and money" - AppEggs.Com (Editor's Pick)
Compare all our alert features other apps can’t match…
* Custom full charge notification percentage (70% to 100%)
* Repeat intervals (Low and Full battery alarms)
* Play sound notifications in a loop
* Quiet hours (Mute alarms at certain hours)
* Mute alerts (Postpone alarms)
* Various vibration lengths
* LED notifications (supported devices)
More options…
* Battery temperature/health on dashboard
* Temperature (Celsius or Fahrenheit) and Voltage in expanded notification area
* "Unplugged/Plugged since" info
* Show smiley or battery level while charging
* Show smiley with sunglasses or battery icon when fully charged
* 1% fix for many Motorola devices
