01. 06. 2014 11:03
Re: GSam Battery Monitor Pro
GSam Battery Monitor Pro v3.12
• Bug Fixes
• New app icon - thanks to Marius Bozgan
• Updated Italian translation
• Added ability to remove Launcher Icon from root companion app
Vice info:Kód: Vybrat vše
https://play.google.com/store/apps/details?id=com.gsamlabs.bbm.pro
Stahuj zde:Kód: Vybrat vše
http://www.tusfiles.net/bv3hopfjpbpc
http://uploadrocket.net/1etpqdo0eup7/GSam_Battery_Monitor_Pro_v3.12.apk.html
http://unlimitzone.com/3gkis1ygjbei/GSam_Battery_Monitor_Pro_v3.12.apk.html
http://uloz.to/x24RDYRj/gsam-battery-monitor-pro-v3-12-apk
http://www70.zippyshare.com/v/70842389/file.html
09. 06. 2014 03:17
GSam Battery Monitor Pro v3.13
požadavky: Liší se podle zařízení
popis: What's New?:
3.13
Bug Fixes
Added Phone Signal graph for non-rooted KitKat users (root users and older Android versions already have this)
Removed INTERNET permission from the Pro version as it's not needed.
info:
stahuj:
http://ulozto.cz/xQczCniQ/gsam-battery-monitor-pro-v3-13-zip
http://ulozto.sk/x81GWw7K/gsam-battery-monitor-pro-v3-13-zip
23. 07. 2014 20:24
GSam Battery Monitor Pro v3.14
https://www.oboom.com/3W2V10NH
http://ul.to/iy2vbpwg
https://www.secureupload.eu/f740ypm6mvig
http://www.tusfiles.net/htajq3zppmea
http://uloz.to/xf9Pdq51/gsam-battery-monitor-pro-v3-14-apk
18. 08. 2014 08:25
GSam Battery Monitor Pro v3.15
http://ul.to/hw6xdefk
http://www.tusfiles.net/q8k61x9fmyrh
http://uloz.to/x8pD9S6z/gsam-battery-monitor-pro-v3-15-apk
http://www19.zippyshare.com/v/52161577/file.html
https://webshare.cz/file/1x36l42vn5/gsam-battery-monitor-pro-v3-15-apk
19. 08. 2014 08:02
GSam Battery Monitor Pro v3.15 Build 7031525
Added new rate-of-change graph option
Added 'Since Screen Off' option for viewing statistics since the last time the screen was powered off. This helps you more easily track background hungry apps.
Created easy access to toggle between different reference points (since custom ref, screen off, unplugged, etc.).
Bug Fixes
http://ul.to/4fds9pdo
http://www.tusfiles.net/4pgjhx8nczq7
http://uloz.to/xSBDdxwJ/gsam-battery-monitor-pro-v3-15-build-7031525-apk
https://webshare.cz/file/5Ax2k03t75/gsam-battery-monitor-pro-v3-15-build-7031525-apk
08. 09. 2014 12:51
GSam Battery Monitor Pro v3.16
Požadavky: Android: liší se podle zařízení
co je nového: Chart Bug Fixes and minor enhancements.
http://ul.to/cj6leka4
https://www.oboom.com/VHZZFDDQ
http://www.tusfiles.net/nn0koeow61mk
https://webshare.cz/group/5634R74pTo/
http://ulozto.cz/xzryiVkr/gsam-battery-monitor-pro-v3-16-apk
http://ulozto.net/xfMjUPkh/gsam-battery-monitor-pro-v3-16-apk
25. 09. 2014 19:08
GSam Battery Monitor Pro v3.17
v3.17
- Maintain graph history for root-companion KitKat and earlier devices
- Updated Czech translation - thanks to Renek
- Bug fixes
http://www.tusfiles.net/8f5vioqrwkle
http://uloz.to/xQQmMCiW/gsam-battery-monitor-pro-v3-17-apk
https://webshare.cz/file/7A01kI2oc4/gsam-battery-monitor-pro-v3-17-apk
http://www14.zippyshare.com/v/66877706/file.html
27. 10. 2014 08:11
GSam Battery Monitor Pro v3.18
Pozadavky: Android 4.4
Full support for Lollipop
Material design will come shortly
http://uloz.to/xc1jdNr9/gsam-battery-monitor-pro-v3-18-apk
https://webshare.cz/file/3tK6ub4n92/gsam-battery-monitor-pro-v3-18-apk
http://www5.zippyshare.com/v/31466486/file.html
http://upfile.mobi/667825
GSam Battery Monitor Pro v3.18 build 703182
https://www.tusfiles.net/imbi3g3vyjs7
http://uloz.to/xjjubgkr/gsam-battery-monitor-pro-v3-18-build-703182-apk
https://webshare.cz/file/6eT5491zOi/gsam-battery-monitor-pro-v3-18-build-703182-apk
19. 11. 2014 10:24
GSam Battery Monitor Pro v3.19 Beta
Požadavky: Android 4.4+ a vyšší
co je nového: Material Design.
http://ul.to/t93pv0c9
http://www.tusfiles.net/lxb2l0smrb24
https://webshare.cz/group/77qbM5uP7f/
http://ulozto.cz/xffNimrQ/gsam-battery-monitor-pro-v3-19-beta-apk
http://ulozto.net/xvy3ArSq/gsam-battery-monitor-pro-v3-19-beta-apk
19. 11. 2014 22:24
GSam Battery Monitor Pro v3.19 Beta (All versions)
Material Design
GSam Battery Monitor Pro v3.19 Beta (2.3+)Kód: Vybrat vše
http://uloz.to/x6aQhqFt/gsam-battery-monitor-pro-v3-19-beta-2-3-apk
https://webshare.cz/file/2ov6ku4gI7/gsam-battery-monitor-pro-v3-19-beta-2-3-apk
GSam Battery Monitor Pro v3.19 Beta (4.4+)Kód: Vybrat vše
http://uloz.to/xRMCo5Za/gsam-battery-monitor-pro-v3-19-beta-4-4-apk
https://webshare.cz/file/4nf8M69w5g/gsam-battery-monitor-pro-v3-19-beta-4-4-apk
