GSam Battery Monitor Pro v3.21 build 1903210 (All versions)
- Added option to show the toolbar on bottom (see the App Theme preference)
- Fixed widget showing wrong icon when using an icon pack (Lollipop)
- Fixed icon pack overlay problem (Lollipop) - Requires IconPack update.
- Fixed kernel wakelock display issues on some devices
- Slovak Translation - thanks to Pavol Šrank
Vice info:Kód: Vybrat vše
https://play.google.com/store/apps/details?id=com.gsamlabs.bbm.pro
GSam Battery Monitor Pro v3.21 build 1903210 (2.3+)Kód: Vybrat vše
Bude casem doplnena - po zverejneni.
GSam Battery Monitor Pro v3.21 build 1903210 (4.4+)Kód: Vybrat vše
https://userscloud.com/t6obx0npyivf
http://ul.to/d0d7x5bw
http://hugefiles.net/r98a12pxho1t
http://uploadrocket.net/oqgwe325tqwk/GSam_Battery_Monitor_Pro_3.21.apk
http://uloz.to/xtcsUcVd/gsam-battery-monitor-pro-v3-21-build-1903210-4-4-5-0-apk
https://webshare.cz/file/3rr1Ul1K92/gsam-battery-monitor-pro-v3-21-build-1903210-4-4-5-0-apk
http://www.embedupload.com/?d=9FMQV4MUFY
