02. 03. 2016 00:14
Ice Box Pro Apps freezer [Root]
Ice Box Pro Apps freezer [Root] v1.1.2
4.0 a vyšší
| ROOT
Popis: Ice Box is a box to freeze and store the apps you dislike but sometime have to use.
https://play.google.com/store/apps/details?id=com.catchingnow.icebox
http://ulozto.cz/xxYRnSpB/ice-box-pro-4allmobile-eu-apk
http://ulozto.net/xyLZi95Y/ice-box-pro-4allmobile-eu-apk
https://webshare.cz/file/1xt31158as/ice-box-pro-4allmobile-eu-apk
Apps in box will be hidden form launcher and won't be able to steal your battery or cellular data in background. You can easily launch them form Ice Box, just like launch form a home screen folder. They'll be frozen automatically after screen lock and can't do anything in background.
Long press app icon to:
- Run App.
- Freeze/Defrost app.
- View App's system detail.
- Open on Google Play.
- Uninstall.
Support desktop widget:
- Quick defrost and run specific app
- Freeze All apps
- Freeze All + Lock Screen Naposledy upravil(a)
milann70 dne 16. 10. 2018 19:11, celkem upraveno 2 x.
14. 11. 2016 17:35
Ice Box - Apps freezer [Root] v2.0.4 [Pro]
4.1 a vyšší
| ROOT
Add new option: Keep foreground app.
Bug fixes and performance improvements.
https://ulozto.cz/!MYKcNomkBwXh/ice-box-pro-apk
https://ulozto.sk/!omHsq7hVzUVZ/ice-box-pro-apk
https://ulozto.net/!47FZ3zOMiU8f/ice-box-pro-apk
https://webshare.cz/file/2z45oj2oG4/ice-box-pro-apk
02. 10. 2017 00:00
Ice Box - Apps freezer v3.0.0 Beta 2 GP [Pro]
4.1 a vyšší
| ROOT
Co je nového: Beta test version 2
https://ulozto.cz/!5aZN51HeT98u/ice-box-pro-3-0-0-beta-2-gp-apk
https://ulozto.net/!VDCSVouHtTJO/ice-box-pro-3-0-0-beta-2-gp-apk
16. 10. 2018 19:13
Ice Box Apps freezer v3.9.2 Beta [Pro]
5.0 a vyšší
- Important notice:
Due to Google's new policy, apps running in background MUST show a notification.
You can disable it manually in your system settings.
- Update database structure.
- Upgrade Island engine support.
- Bug fixes and performance improvements
https://douploads.com/8eajsnmvyeq9
https://upload4earn.org/d1ph3d60th4r
http://ul.to/l93xb6al
14. 03. 2019 14:38
Ice Box Apps freezer v3.10.0 G build 958 Final [Pro]
5.0 a vyšší
Oprava kompatibility s aplikací Nevolution na Androidu 9.
https://douploads.com/dtzp5u1p4bf7
https://upload4earn.org/68rhh5wrh6qp
https://speed4up.com/w4vyays0e3oj.html
https://uploadbuzz.org/omvwkm6ulvil
http://ul.to/e9482inw
https://uploadev.com/jcu4qid3xw7m
