15. 06. 2016 03:12
Pixoff: Battery Saver PRO
Pixoff: Battery Saver PRO v2.2
20,-Kc
4.4 a vyšší
Popis: Saves battery by applying a filter that turns off pixels of AMOLED screens.
https://play.google.com/store/apps/details?id=com.urysoft.pixelfilterpro
https://ulozto.cz/xkUkG6Y2/pixoff-battery-saver-pro-4allmobile-eu-apk
https://ulozto.sk/xgaK3nQo/pixoff-battery-saver-pro-4allmobile-eu-apk
https://ulozto.net/xMUrXnJt/pixoff-battery-saver-pro-4allmobile-eu-apk
https://webshare.cz/file/7fj5k27LvQ/pixoff-battery-saver-pro-4allmobile-eu-apk
Saves battery by applying a filter that turns off pixels of AMOLED screens, also incorporates the possibility of make a filter night decreasing so damaging blue light and you can further reduce battery consumption with facility to put a wallpaper to true black.
AMOLED screens doesn't have a backlight at all. Instead, each little sub-pixel is like a tiny red, blue, or green colored light. If the screen is instructed to display black, it doesn't need to block any light, it simply doesn't light up any of the little colored sub-pixels. Dotazy na SZ.
22. 06. 2016 03:11
Pixoff: Battery Saver PRO v3.1.0
4.4 a vyšší
Co je nového: Black pixels save you a lot of power because those pixels can be turned completely off. There is a relationship between brightness and power, but to really save juice you need a true black.
https://ulozto.cz/xMyu3Ys9/pixoff-battery-saver-pro-4allmobile-eu-apk
https://ulozto.sk/xuDzQroZ/pixoff-battery-saver-pro-4allmobile-eu-apk
https://ulozto.net/xQxcAoUK/pixoff-battery-saver-pro-4allmobile-eu-apk
https://webshare.cz/file/29453y2FK4/pixoff-battery-saver-pro-4allmobile-eu-apk
16. 08. 2016 02:49
Pixoff: Battery Saver PRO v4.0.0
4.4 a vyšší
Co je nového: Greater battery savings.Improve speed UI.
https://ulozto.cz/!XzRS59Er9/pixoff-battery-saver-pro-apk
https://ulozto.sk/!9JGSFHNVd/pixoff-battery-saver-pro-apk
https://ulozto.net/!TNXqWaCxC/pixoff-battery-saver-pro-apk
https://webshare.cz/file/3Pv5lA1qu6/pixoff-battery-saver-pro-apk
21. 02. 2017 23:47
Pixoff: Battery Saver v4.3.2 [Pro]
4.4 a vyšší
- Improved matrix generator engine
- Added feature of Flip & Pocket
- Added anti uneven wear system
- Pixel filters support devices with navbar
- Wallpaper is restored when the filter is no longer active
- Added creation of shortcuts on the desktop
- When the filter is turned off, the notification can be canceled or removed.
- Added night mode toggle button in notification
https://ulozto.cz/!cZdcbdxEcr5S/pixoff-battery-saver-4allmobile-eu-apk
https://ulozto.sk/!asf9N22kRWVj/pixoff-battery-saver-4allmobile-eu-apk
https://ulozto.net/!aJuv16K5iAUf/pixoff-battery-saver-4allmobile-eu-apk
https://webshare.cz/file/7gT6Dhia32/pixoff-battery-saver-4allmobile-eu-apk
