Internet Speed Test je výkonný, pokročilý nástroj, který vám pomůže měřit rychlost připojení k internetu v systému Android.
https://play.google.com/store/apps/details?id=pl.speedtest.android&hl=en
https://ulozto.cz/!ZJgZGdn2r55a/v-speed-speed-test-premium-signed-apk
https://webshare.cz/file/5954wz53h4/v-speed-speed-test-premium-signed-apk
• wifi and mobile signal finding tool,
• the ability to select the default server,
• tests download speed (downlink)
• tests upload speed (uplink)
• measurement of data transfer time delays (latency, ping)
• two typical data transfer units (kbps, Mbps),
• automatic selection of test parameters depending on the type of a connection (WiFi, 2G/3G mobile)
• basic information about the connection (IP address, Internet service provider and organization, SIM operator or name of the WiFi network)
• history of results with options to filter and sort the list according to the different criteria,
• ability to customize test parameters to meet your needs (the duration of the test, the number of connections),
• detailed information about the tests (measured value of download/upload/ping, connection type, date, settings),
• easily copy your IP address and results to the clipboard,
• vibration handling,
• publication of results on social networking sites (Facebook, Twitter, Google+, etc.),
• compatibility mode with less powerful and older devices (switch on/off tween animations)
• appropriate warnings for testing mobile Internet.
