Pozadavky: Android 2.32 a vyssi Popis: Handy Photo was designed for those with a strong passion for photo editing. The app is a perfect choice when it comes to correcting and enhancing photos from all possible angles.
- Fixed resources downloading bug.
Instructions:
1.Install apk
2.Copy SD DATA to Android/obb
3.Run the app
Handy Photo byl navržen pro ty, kteří se silnou vášní pro úpravu fotografií. Aplikace je ideální volbou, pokud jde o nápravu a zlepšení fotografií ze všech možných úhlů.
Edit your photo with the Handy Photo's complete set of truly powerful tools and obtain the results that will definitely impress you and all those viewing your works of art.
* Uncrop your photos in a unique way *
The tool is called Magic not accidentally. It enables the users to uniquely uncrop photos. No other app could do it. The Magic Crop is unique for one more reason. It allows straightening a crooked horizon without sacrificing the photo’s original size.
* Let the objects in your photos come alive *
Is it possible to move the objects in your photos in just a few taps? The answer is yes when it comes to the Move Me tool. Carry the object to any other place or photo and be satisfied that it suits there to a tee.
* Perform photo retouching in the best possible way *
Remove all undesired objects and blemishes from your photos in a tap. Mobile retouching has never been so fast and easy.
* Color and tone balance your photos *
Thanks to a complete toolset for adjusting color and tone of photos, you can properly balance your images’ Brightness, Contrast, Saturation, Warmth, Shadows, Highlights, etc. levels to make the photos look vivid and natural.
* Apply stunning photo filters *
A total of more than twenty filters, namely Black and White, Bleach Bypass, Color Standout, Cross Process, Dramatic, Duotone, Fog, Glow, Golden, HDR, Halftone, Ink, Lomo, Old Photo, Polarization, Polaroid, Sepia, Sketch, Smart Contrast, Tilt Shift, Tiny Planet, Vignette, and Vintage, are always at your disposal in case you feel like changing the atmosphere of any of your photos. All they are equally amazing, easy to adjust and apply, and flexible to work with.
* Add marvelous textures *
Create the atmosphere of your photo stories yourself with the Handy Photo’s pack of terrific textures (more than 90). Apply them to enhance your photos and make them truly pop. You can select from the following groups of textures: Cloth, Clouds, Frost and Ice, Grunge, Paper, Water, Wood.
The textures are adjustable, so make some settings to the texture you have selected, apply it, and you will become even more fascinated with your photo.
* Add attention-grabbing frames *
Before showing your photo to the whole world, it’s quite important to appropriately frame it. The Handy Photo’s excellent collection of frames serves just that purpose. Put the final touches on your photos by adding the following frames to them: Carton, Film, Grunge, Photo Album, Polaroid, and Retro Photo.
* THE APP FEATURES *
★ Move Me technology for intellectual objects extraction and moving
★ Magic Crop tool with unique photo “un-cropping” function
★ The best retouching technology for mobile platforms
★ Impressive collection of professional photo filters
★ Complete sets of high quality textures and frames
★ 100% size image viewing
★ Up to 36 MP support
★ Optimized for multi-core and GPU processors
★ Stylish and intuitive UI
Brought to you by the developers of TouchRetouch!
* DEVICES SUPPORT *
All devices running Android 2.3 or newer and supporting ARMv7.
Depending on the amount of total RAM available, the following resolution images processing is allowed:
2 GB of RAM - 24 MP
1 GB of RAM - 16 MP
786 Mb of RAM - 12 MP
512 Mb of RAM - 8 MP
less than 512 MP of RAM – 5 MP
- Added possibility to open RAW images
- Added possibility to download textures
- Optimized app binary size
- Improved UI
- Fixed some bugs
- Made some improvements
- Fixed black screen in MoveMe;
- Fixed Raw file opening according to size which is set;
- Fixed rotation after lock screen;
- Other small fixes and improvements.
