10 příspěvků •Stránka 1 z 1
iNoty
18. 08. 2013 14:34
iNoty
iNoty v1.0.1
(24,- Kc)
Popis: iPhone style status bar replacement with iOS 7 style. It is best when used with iLauncher.
* Calendar is only supported on Android >= 4.0.
* Tablet is not supported.
v1.0.1
- Now automatically remove confirmed notifications.
- Network connection detection improved.
- Fixed a bug that notification message showed up in fullscreen mode.
- Now sliding animation of notification message works on Gingerbread.
https://play.google.com/store/apps/details?id=net.suckga.inoty
http://uloz.to/xTJK2E6z/inoty-v1-0-1-4allmobile-eu-apk
https://mega.co.nz/#!vF5hzL5b!V1zyPV_-hk4iY5iCnfIuShRb86832dy1U-0OMZjgeMo
http://www23.zippyshare.com/v/18602168/file.html
22. 08. 2013 21:29
Re: iNoty
iNoty v1.0.2.2
v1.0.2
- Consequent swipe down after the status bar pulled down will show the original status bar. This may be useful to access the original status bar's system controls. (Accessibility service should be enabled to use this feature.)
http://uloz.to/xhtNikXu/inoty-v1-0-2-2-4allmobile-eu-apk
https://mega.co.nz/#!OU5BQIZC!N6wH4Q7gpEw2wO5uWO1bNhNpyxsx7hyLEJAHUSG7CGc
http://www11.zippyshare.com/v/73366801/file.html
21. 09. 2013 14:03
Re: iNoty
iNoty v1.0.52
v1.0.5
- Now 'today' and 'all' tabs can be switched by swiping.
v1.0.4
- Added some personalization options.
v1.0.3
- Fixed wifi bug
- Fixed a problem that only one schedule was displayed on timetable.
- misc.
http://uloz.to/xMWMnMKw/inoty-v1-0-52-4allmobile-eu-apk
http://www71.zippyshare.com/v/44254990/file.html
https://webshare.cz/file/4gP3zn19x6/inoty-v1-0-52-4allmobile-eu-apk
08. 10. 2013 19:14
Re: iNoty
iNoty v1.0.6.1
http://uloz.to/xRFa3keW/inoty-v1-0-6-1-4allmobile-eu-apk
http://www33.zippyshare.com/v/42109563/file.html
09. 03. 2014 01:47
Re: iNoty
iNoty v1.1.0
v1.1.0.1
- Fixed a bug preferences didn't saved.
v1.1.0
- Improved counting telephony signal. Now LTE signal is displayed normally.
- Added fading effect.
https://play.google.com/store/apps/details?id=net.suckga.inoty2
http://www21.zippyshare.com/v/90012226/file.html
http://hugefiles.net/jj547zd18bv4
http://www.kingfiles.net/pdmxz58cotzo/iNoty_1.1.0.apk
https://www.tusfiles.net/gqfl27gabcl1
http://www15.zippyshare.com/v/21102675/file.html
http://www.tusfiles.net/tksvioahpdnd
http://uloz.to/xH3LP5nR/inoty-v1-1-0-apk
http://ulozto.sk/xri98zPv/inoty-v1-1-0-apk
23. 01. 2015 03:01
Re: iNoty
iNoty v1.2.1
Co je nového: Fixed crashes and bugs.iLauncher 3.3.3 is required.
http://ul.to/d2denc3w
https://userscloud.com/guquiyw6k2oz
https://www.tusfiles.net/etm76bswo45u
http://ulozto.cz/xd6gkV87/inoty-1-2-1-4allmobile-eu-apk
http://ulozto.net/xf45zurQ/inoty-1-2-1-4allmobile-eu-apk
https://webshare.cz/file/70h6B64Af1/inoty-1-2-14allmobile-eu-apk
19. 02. 2015 12:42
Re: iNoty
iNoty v1.2.2
- Each notifications can be deleted individually by swiping left.
- Updated clear button style.
http://ul.to/dthibcsh
https://www.tusfiles.net/50b6u06ws7gq
http://ulozto.cz/xUPDjFX2/inoty-1-2-2-4allmobile-eu-apk
http://ulozto.net/xU5oJDvo/inoty-1-2-2-4allmobile-eu-apk
https://webshare.cz/file/5xp19y4lE1/inoty-1-2-24allmobile-eu-apk
22. 02. 2015 04:57
Re: iNoty
iNoty v1.2.2.1
Co je nového: Fixed a crash occurred on Gingerbread.
http://ulozto.cz/xAAeELVd/inoty-v1-2-2-1-4allmobile-eu-apk
http://ulozto.net/xpkdCGX8/inoty-v1-2-2-1-4allmobile-eu-apk
https://webshare.cz/file/2mV6K325b7/inoty-v1-2-2-14allmobile-eu-apk
22. 03. 2015 11:47
Re: iNoty
iNoty v1.3.0.1
v1.3.0
- Ongoing notification is displayed in 'today' tab. (Only supported on Android 4.3+)
v1.3.0.1
- Fixed a crash on Android 4.2-
http://uloz.to/xGH6u2o4/inoty-v1-3-0-1-apk
http://ulozto.sk/xKYwSsFm/inoty-v1-3-0-1-apk
https://webshare.cz/file/6u528Pks2y/inoty-v1-3-0-1-apk
20. 04. 2016 09:06
Re: iNoty
iNoty v1.5.2
v1.5.2
- Reduced system status bar overlay problem
- Notification center can be turned off so that only status bar can be used. This might not work correctly on some devices.
https://uploadshub.com/2droxht30ucy
https://revclouds.com/zog2rhxcwig9
https://userscloud.com/77l52ifwhpuf
https://uplod.it/q9ie33ib5182
