26. 01. 2014 22:34
DigiHUD Speedometer
DigiHUD Speedometer 1.3.0
Popis: DigiHUD Speedometer is a free digital head up display (HUD) that shows useful speed and distance information for your journey.
Version 1.3.0:
* Important information about screen burn-in added
* Initial brightness level reduced
Version 1.2.9:
* Lite view re-draw fix: Speed unit has been removed.
Vice info:Kód: Vybrat vše
https://play.google.com/store/apps/details?id=org.mrchops.android.digihudpro
Stahuj zde:Kód: Vybrat vše
http://www78.zippyshare.com/v/74362891/file.html
http://www.tusfiles.net/izc7mvyukv6f
http://ul.to/oz0fzfpu
http://www36.zippyshare.com/v/6860514/file.html
DigiHUD Speedometer is a free digital head up display (HUD) that shows useful speed and distance information for your journey. The display can be switched between normal viewing and HUD mode which mirrors the display for viewing as a reflection in a vehicle windshield (most useful at night, depending on the device's brightness).
DigiHUD can now appear as a floating window on top of other apps or your homescreens.
Currently displays the following information:
Current speed (choose MPH, KMH or KTS)
Average speed, this trip
Maximum speed, this trip
Trip distance (three trip counters)
Compass
Odometer (found under Statistics)
Current time
Digit color change when above your set warning speed
Battery power level
Satellite lock obtained icon
Main Menu
Opened by touching the speed displayed in the centre of the screen, the menu allows you to:
Exit DigiHUD: exit the app
Window/Background Mode: Close and open as a re-sizeable floating window
HUD view / Normal view: Switch between HUD (mirrored) and normal displays
Speed Unit: Change between MPH, KMH or KTS
Set Warning Speed/Sound: The speed at which the digit color will change to red. An audible alert can also be enabled here
Brightness: Adjust the screen brightness
Display Color: Choose from 10 customizable colors
Lock screen rotation: keep the screen in its current rotation.
Display Preferences: enable/disable screen elements
Statistics: odometer, trip distance, top speed and average speed and version number
Help: show help and other information
*This application requires the use of the GPS receiver, which may increase battery usage.*
Although we strive to make all readings as accurate as possible they are only as accurate as your device's sensors and should only be regarded as approximations.
Using DigiHUD
Swipe left or right to switch between Full and Lite views
Swipe up or down to switch between HUD (mirrored) and normal displays
Touch the trip counter to cycle through the three counters
Long-pressing on a speed or trip value will reset it
Long-press the speed unit to choose between MPH, KMH and KTS from the popup menu (also in the Main Menu)
When in window mode touch the DigiHUD icon for a menu to switch to the fullscreen app or exit
13. 01. 2015 22:09
DigiHUD Pro Speedometer v1.0.8
Version 1.0.8
Bug fixes:
* Fixed a DST bug in sunrise/sunset calculations
* Disclaimer and What's New dialogs can't be cancelled
* Possible Null Location object fixed
https://www.tusfiles.net/w07m6v4rh76i
http://unlimitzone.com/qqhnchazbqez/org.mrchops.android.digihudpro-1.apk.html
http://uloz.to/xD8kXZX2/digihud-pro-speedometer-v1-0-8-apk
https://webshare.cz/file/7697ku2ii3/digihud-pro-speedometer-v1-0-8-apk
17. 02. 2015 20:27
DigiHUD Pro Speedometer v1.0.10
Version 1.0.10.1
This is an emergency patch to correct an issue which was preventing the floating Window being displayed.
Bug Fixes:
* Missing default size and position values for the Window caused it to be invisible for new installs
* Correct Day/Night brightness settings which were misbehaving on some devices
http://uloz.to/xM5neYXT/digihud-pro-speedometer-v1-0-10-www-4allmobile-eu-apk
http://ulozto.sk/xKKxQSfL/digihud-pro-speedometer-v1-0-10-www-4allmobile-eu-apk
https://webshare.cz/file/6oc4oQ1Xa2/digihud-pro-speedometer-v1-0-10-www-4allmobile-eu-apk
19. 02. 2015 09:36
DigiHUD Pro Speedometer v1.0.10.1
http://ul.to/dnol4x3k
https://www.tusfiles.net/8pak2hftpufh
http://ulozto.cz/x5TPQJRH/digihud-pro-speedometer-v1-0-10-1-4allmobile-eu-apk
http://ulozto.net/xPaZGprQ/digihud-pro-speedometer-v1-0-10-1-4allmobile-eu-apk
https://webshare.cz/file/2l469n5Sb2/digihud-pro-speedometer-v1-0-10-14allmobile-eu-apk
01. 02. 2016 00:31
DigiHUD Pro Speedometer v1.1.4
* You can finally turn all icons on and off in Settings
* New Setting to turn off confirmation dialogs when resetting values
* Removed some popup messages, e.g. when switching trip meters
* Update the displayed trip value when switching/resetting and not moving
* The Setting 'Open Menu on screen tap?' now applies to ALL screen modes
* Sharper compass image
http://ulozto.cz/x9LgD2JN/digihud-pro-4allmobile-eu-apk
http://ulozto.net/xVa3P7ow/digihud-pro-4allmobile-eu-apk
https://webshare.cz/file/2z627g2c67/digihud-pro-4allmobile-eu-apk
26. 11. 2016 06:50
DigiHUD Pro Speedometer v1.1.8
Co je nového: Corrected the datetime format for route log exports.Fix speed warning sound not playing correctly.
https://ulozto.cz/!PCmDb79EH3tV/digihud-pro-1-1-8-apk
https://ulozto.sk/!7S3HKCBbbNGy/digihud-pro-1-1-8-apk
https://ulozto.net/!FEEbIAxks8ha/digihud-pro-1-1-8-apk
https://webshare.cz/file/u13Up56p5n/digihud-pro-1-1-8-apk
29. 03. 2017 02:44
DigiHUD Pro Speedometer v1.1.9 [Paid]
Co je nového: Added Russian language.
https://ulozto.cz/!t9h5Ptk8dUxX/digihud-pro-speedometer-v1-1-9-apk
https://ulozto.sk/!4uOsXBT7k028/digihud-pro-speedometer-v1-1-9-apk
https://ulozto.net/!8OryXvmSQ3JI/digihud-pro-speedometer-v1-1-9-apk
https://webshare.cz/file/4uXec5onSe/digihud-pro-speedometer-v1-1-9-apk
15. 09. 2019 20:16
DigiHUD Pro Speedometer v1.1.15 [Paid]
35,-Kč
Oprava - Selhání aplikace kvůli zastaralé třídě v Google Map.
https://mixloads.com/qbu21w2f7xus
https://dropapk.to/eknvfqgkg5qh
https://uploadrar.com/xy0pb2ovx824
https://www.uploadship.com/2b8066d4afcef241
