19. 06. 2014 14:24
Sleep Cycle alarm clock
Sleep Cycle alarm clock v1.0.570
(42,- Kc)
Popis: Waking up made easy.
An intelligent alarm clock that analyzes your sleep and wakes you in the lightest sleep phase – the natural way to wake up feeling rested and relaxed.
- Fix for unable to create custom sleep notes
Vice info:Kód: Vybrat vše
https://play.google.com/store/apps/details?id=com.northcube.sleepcycle
Stahuj zde:Kód: Vybrat vše
http://www74.zippyshare.com/v/1455331/file.html
https://www.tusfiles.net/gmkeaae0st1o
http://hugefiles.net/0kwvs3a1p9bk
http://www.datafilehost.com/d/b49fb2b5
http://unlimitzone.com/xp0d18kwxoot/Sleep.Cycle.alarm.clock_v1.0.570.apk.html
http://rapidgator.net/file/47b15095864665c8929ae62352e52f47
Sleep Cycle helps millions of people to wake up rested!
Featured in: CNN, Wired, The Guardian, The Wall Street Journal, BBC, The New York Times and many more.
"It just works. Period. It does exactly what it advertises which is absolutely amazing."
-- 5/5 stars on 148apps.com
Sleep cycle is continuously rated as the best smart alarm clock, Sleep Cycle is now the worlds most used intelligent alarm clock.
* Sleep Cycle monitors your movement during sleep using the extremely sensitive accelerometer in your phone.
* Sleep Cycle then finds the optimal time to wake you up during a 30 minute window that ends at your set alarm time.
* Look at the screenshots for recommended phone placement.
As you sleep you go through different phases, ranging from deep sleep to light sleep. The phase you are in when your alarm goes off is critical for how tired you will feel when you wake up.
Since you move differently in bed during the different phases, Sleep Cycle can use the accelerometer in your phone to monitor your movement and determine which sleep phase you are in.
Sleep Cycle wakes you when you are in your lightest sleep phase.
Sleep Cycle was developed using proven sleep science and years of research and development.
MAIN FEATURES
√ Waking up made easy! Sleep Cycle analyzes your sleep and wakes you in your lightest sleep phase.
√ Detailed sleep statistics and sleep graphs for every night.
√ 15 carefully selected, high quality, alarm melodies.
√ Use your own music as wake up sound
√ Snooze by shaking or tapping the phone lightly.
√ Customizable wake up window. From instant (regular alarm clock) up to 90 minutes.
√ Background mode - set your alarm and exit Sleep Cycle - sleep analysis will continue in the background
√ Sleep notes - see how events such as drinking coffee, eating too much or having a stressful day affect your sleep quality
√ Long term graphs - track sleep quality over time, see which days of the week you sleep best and much more
29. 06. 2014 22:38
Sleep Cycle alarm clock v1.0.575
co je nového:
Bug fixes for user reported crashes
https://www.tusfiles.net/ctjqh69cu4fn
http://ulozto.cz/xVwiaAP5/sleep-cycle-alarm-clock-v1-0-575-apk
http://ulozto.net/x33hunYt/sleep-cycle-alarm-clock-apk
11. 07. 2014 09:14
Sleep Cycle alarm clock v1.0.582
co je nového:
Fix for the situation where some phones stopped responding to movement.
Fix for devices going into deep sleep preventing the alarm to start. Please contact support is you are still having this issue.
Fix for unable to set alarm between 11PM and 12AM on 12-hour clocks.
Bug fixes for user reported crashes.
Miscellaneous performance and stability improvements.
https://www.tusfiles.net/9fzk671vjvag
https://webshare.cz/group/6dn3gN34dI/
http://www71.zippyshare.com/v/7343006/file.html
http://www68.zippyshare.com/v/25320995/file.html
http://ulozto.cz/xDogSJXu/sleep-cycle-alarm-clock-v1-0-582-apk
10. 12. 2014 01:20
Sleep Cycle alarm clock v1.1.653
- na GP se k teto verzi neuvadi
https://www.tusfiles.net/m2moxfps4bpf
http://uloz.to/xCsx1Dhn/sleep-cycle-alarm-clock-v1-1-653-apk
https://webshare.cz/file/2mp6tW37j1/sleep-cycle-alarm-clock-v1-1-653-apk
10. 12. 2014 18:43
Sleep Cycle alarm clock v1.2.655
- New Slide-to-unlock pattern; slide the entire screen upwards to end alarm
- Post your sleep to RunKeeper
- Support for Nexus 6
- Bug fixes and stability improvements
https://www.tusfiles.net/3x7em97qr5qm
http://uploadrocket.net/96qkwuxyta5f
http://uloz.to/xCd3EyZv/sleep-cycle-alarm-clock-v1-2-655-apk
https://webshare.cz/file/1fw53X6572/sleep-cycle-alarm-clock-v1-2-655-apk
12. 12. 2014 20:51
Sleep Cycle alarm clock v1.2.656
Fix for the 0% sleep quality issue. Old sessions will also be repaired, so no data is lost.
Support for Nexus 6
https://www.tusfiles.net/828q02bfwmw9
https://userscloud.com/1k6kt26w8nh9
http://uloz.to/xgidJdDi/sleep-cycle-alarm-clock-v1-2-656-apk
https://webshare.cz/file/7Og3l3ekh6/sleep-cycle-alarm-clock-v1-2-656-apk
25. 10. 2015 19:21
Sleep Cycle alarm clock v1.3.698
- Fix a bug where the app was unable to communicate with the SleepSecure server
- Now able to install on Nexus 5X
http://uloz.to/x8rveppB/sleep-cycle-alarm-clock-v1-3-698-apk
https://webshare.cz/file/2Q227a7kRw/sleep-cycle-alarm-clock-v1-3-698-apk
https://uploadex.com/0m5gixzdqygv
https://dailyuploads.net/gamft816fjte
https://userscloud.com/i5rkjcr8iyah
http://ul.to/p83t2735
Henry1
09. 09. 2009 07:54
23. 02. 2018 07:42
Sleep Cycle alarm clock v2.0.1745 Premium
What's New :
v2.0.1745
No more phones in bed with Sleep Cycle patented sound analysis sleep tracking!
Simply place the phone on your nightstand. Sleep Cycle will track your sleep using sound analysis and wake you up in light sleep. The natural way to wake up feeling rested. The new patented sound analysis technology features an intelligent algorithm, trained to accurately identify sounds generated by your movements in bed, and will automatically filter out all other sounds from the surrounding environment.
Google Play :
Download :
https://ulozto.cz/!ot0qwmKb9iGK/sleep-cycle-alarm-clock-v2-0-1745-apk
https://userscloud.com/vospbk32z3pe
https://upload4earn.com/wpns81qip40t
18. 05. 2018 11:34
Sleep Cycle alarm clock v2.0.1891 [Premium]
4.1 a vyšší
Co je nového:• Přidané zkratky pro aplikace - rychle spusťte budík přímo z domovské obrazovky
• Aktualizované uživatelské rozhraní pro oznámení
• Aktualizovaná ikona režimu spánku
• Obecné opravy a vylepšení chyb
https://uloz.to/!2Wb61hiL5ozT/sleep-cycle-premium-v2-0-1891-apk
https://ulozto.net/!0fnMkJxYKjCI/sleep-cycle-premium-v2-0-1891-apk
23. 05. 2018 01:01
Sleep Cycle alarm clock v2.0.1893 [Premium]
4.1 a vyšší
https://uloz.to/!bs5LDqmQPnAC/sleep-cycle-alarm-clock-v2-0-1893-premium-apk
https://ulozto.sk/!MUA1BtSB1Qcn/sleep-cycle-alarm-clock-v2-0-1893-premium-apk
