17. 09. 2014 19:53
Malwarebytes Anti-Malware
Malwarebytes Anti-Malware v1.04.3
Požadavky: Android 2.3+ a vyšší
Popis: Malwarebytes Anti-Malware Mobile chrání váš telefon nebo tablet před malwarem, infikovanými aplikacemi a od neoprávněného sledování.
https://play.google.com/store/apps/details?id=org.malwarebytes.antimalware
http://uploaded.net/file/qt7stjm5
https://webshare.cz/group/4pl5b95i37/
http://ulozto.net/xaJrVXX2/malwarebytes-anti-malware-apk
• Detects and eliminates malware, including spyware and Trojans
• Scans your apps for malicious code or Potentially Unwanted Programs (PUPs)
• Scans archived files and files stored on external SD card for complete coverage
• Stops unauthorized access to your personal data
• Scans your Android device for security vulnerabilities
• Identifies applications that are tracking your location
Take your anti-malware protection to go
Malwarebytes Anti-Malware Mobile guards your identity and personal data on-the-go. So you and your Android smartphone or tablet are safe from malware and unauthorized surveillance. Wherever you are. Whenever you go.
Make your smartphone smarter
Is that app or downloaded photo safe? With Malwarebytes Anti-Malware Mobile, you never have to worry again. Powerful anti-malware and anti-spyware technology protects your Android device. Detecting Trojans, spyware, and other Potentially Unwanted Programs (PUPs) before they can steal your identity, eavesdrop, or degrade your mobile experience.
Choose what you keep private
Cybercriminals, and even legitimate companies, can collect private information from your Android device. Where you go. Who your contacts are. Malwarebytes Anti-Malware Mobile identifies what your applications are doing, and which private information is being accessed. So you can control who knows, and what they know.
Close the security holes
Malwarebytes Anti-Malware Mobile automatically recognizes security vulnerabilities in your Android device’s settings. Then it makes recommendations on how to close those holes.
Make your smartphone lighter
Mobile security software is typically bloated with location features (Remote Lock, Locate on a Map, etc.). These features can already be found in your Android Device Manager—why duplicate them? Malwarebytes Anti-Malware Mobile preserves your device’s performance by adding only the necessary security features. And you can update its database over a WiFi network to reduce your data usage.
Anti-Malware/Anti-Spyware
• Scans applications and files for malware and spyware
• Scans automatically when files or apps are accessed (real-time) or only when activated manually (on-demand)
• Scans native memory and SD card
• Schedules automatic scans
• Detects Potentially Unwanted Programs (PUPs)
• Updates the protection database automatically
• Updates over a WiFi network if preferable
Privacy Manager
• Identifies every application’s access privileges in detail
• Breaks down access privileges by category: Contacts, Identity Information, Simple Message Service (SMS), and Security Settings
Security Audit
• Identifies security vulnerabilities on your device, suggests remediation
• Links seamlessly to Android Device Manager’s device location features so the device can be located, locked, or reset if it is lost or stolen
Application Manager
• Identifies which applications are currently running
• Identifies installed applications
• Enables custom whitelisting of approved apps Dotazy na SZ.
25. 08. 2017 02:14
Malwarebytes Anti-Malware v3.0.0.26 [Premium]
4.1 a vyšší
Co je nového:* Prémiová verze
- model Freemium (oprava je vždy zdarma)
- zkušební podpora (30denní zkušební verze Premium)
- Stávající uživatelé získali základní ochranu v reálném čase bez dodatečných nákladů
• Pokročilá ochrana (pouze Premium)
- Anti-ransomware, s nápravou
- Detekce škodlivého softwaru v reálném čase
- Hluboké skenování, které detekuje ransomware maskovaný mutací
- Skenování a instalace (skenování aplikací před instalací)
• Widgety pro domácí plochu
• Automatické skenování textu pro phishingové odkazy
• Ovládání SMS zařízení
https://ulozto.cz/!AHNfyER2N5PB/malwarebytes-premium-3-0-0-26-apk
https://webshare.cz/file/68t3j9385g/malwarebytes-premium-3-0-0-26-apk
07. 10. 2017 01:24
Malwarebytes Anti-Malware v3.1.0.8 [Premium]
4.1 a vyšší
Co je nového:* Přidáno Safe Browsing Scanner (Premium)
* Vyšší kompatibilita s Androidem 8 (Oreo)
* Přidány zlepšení stability a opravy chyb
https://ulozto.sk/!tBcyVZ7ZeMRx/malwarebytes-premium-3-1-0-8-apk
https://ulozto.net/!tpI1sohqgMFa/malwarebytes-premium-3-1-0-8-apk
18. 05. 2018 11:44
Malwarebytes Anti-Malware v3.3.0.6 [Premium]
4.1 a vyšší
Co je nového:+ Opravy chyb.Blokování hovorů (funkce Beta - používá oprávnění k telefonování a kontaktům).
Stahuj zde:PREMIUM features Unlocked
https://ulozto.sk/!sjJgD2EC4Cjq/malwarebytes-premium-v3-3-0-6-apk
https://ulozto.net/!7z2x4AAsHxrY/malwarebytes-premium-v3-3-0-6-apk
20. 05. 2018 22:33
Malwarebytes Anti-Malware v3.3.0.7 [Premium]
4.1 a vyšší
+ Blokování hovorů (funkce Beta - používá oprávnění k telefonování a kontaktům)
https://uloz.to/!0d6gOc3i2JrH/malwarebytes-premium-v3-3-0-7-apk
https://ulozto.sk/!4qnVhYr07luZ/malwarebytes-premium-v3-3-0-7-apk
18. 12. 2018 12:03
Malwarebytes Anti Malware v3.5.0.4 [Premium]
4.1 a vyšší
Vylepšení:
• Vylepšená detekce mincí
Stabilita / problémy jsou fixní
• Drobné opravy a vylepšení chyb
https://uploadbuzz.org/rkoz9ekwmcsb
https://douploads.com/2xwv766mmerg
https://upload4earn.org/oy9vsf5u5qli
http://ul.to/5epzqn7v
