12. 05. 2015 01:58
Meteogram widget
Meteogram widget - Donate v1.6.10
47,-Kc
Popis: This is the "Donate" version of Meteogram Widget. This paid version is meant to support further development of the widget and other apps. This version has as extra functionnality a widget showing a long term forecast (= forecast after the next 48h) homescreen and add it back.
color=#FF4000]Vice info:[/color]
https://play.google.com/store/apps/details?id=be.inet.rainwidget.donate
http://ulozto.cz/xzugniVd/meteogram-widget-donate-v-1-6-10-4allmobile-eu-apk
http://ulozto.net/x7mse4df/meteogram-widget-donate-v-1-6-10-4allmobile-eu-apk
https://webshare.cz/file/2q91fV7Az5/meteogram-widget-donate-v-1-6-10-4allmobile-eu-apk
Meteogram widget comes with 2 types of widgets: the first widget shows the weather for the next 2 days (detailed), and a bigger widget that shows the weather for the next 5 days. This Donate-version adds a third widget, showing the long term forecast (= after the next 48h).
The first widget shows a detailed view what the weather will be like for the next 2 days. The widget shows a chart, called a meteogram, where the temperature, type of weather (rain, snow, sun, ...), precipitation, wind speed and wind direction are shown on. This widget is very useful when you want to know when exactly the rain will fall (one hour precision). The amount of precipitation is also shown.
The second widget is a combination of the first one with the weather for the next 5 days: minimum and maximum temperature, weather type and precipitation.
The third widget (only available in the Donate-version) shows the weather forecast after the next 48h.
The widgets have the following features:
* Temperature, type of weather, pressure, precipitation, wind speed and wind direction shown on a chart
* Forecast for the next 2 days or next 5 days
* One hour precision
* Possibility to add several widgets, each with its own location
* Show the forecast for your current location
* Colors are customizable
Remarks:
- These are widgets for the home screen.
- When you have troubles with a widget, please contact us (see email address developer). Dotazy na SZ.
29. 01. 2016 11:12
Meteogram widget - Donate v1.6.26.2
- 1.6.26 / .1 / .2:
Material design
Internal improvements
- 1.6.25:
Some new icons
- 1.6.24:
Improved Swedish translation
- 1.6.23:
Translation into Russian and Lithuanian
- 1.6.22.1/.../.5:
Bug fixes
- 1.6.22:
Bug fix updating issue
- 1.6.21(.1):
Swedish translation
Vice info:Kód: Vybrat vše
Stahuj zde:Kód: Vybrat vše
https://revclouds.com/rk8zew7zt8s5
https://userscloud.com/l9jvlo42h7td
http://ul.to/j4jfvta2
19. 03. 2016 20:37
Meteogram widget - Donate v1.6.28.1
This version introduces a new feature: a new tap zone allows you to open an hourly/3-hourly overview of the complete forecast. This can be useful when you want to see the exact forecast at a certain time. This feature can be activated in the "Advanced settings".
- 1.6.27:
About section
https://uploadshub.com/vsunncyqw9rm
https://uplod.it/s7abhauffecc
https://revclouds.com/cacgi7cab4rb
https://userscloud.com/3iugeuce2bek
30. 04. 2016 16:35
Meteogram widget - Donate v1.6.29.1
This version introduces a new feature: minimum and maximum temperature badges. Those badges give a clear view when, during the forecast period, the minimum and maximum temperature falls. This feature can be activated in the "Configure line style" part.
- 1.6.28.3:
Added precipitation on forecast overview
- 1.6.28.2:
Forecast overview now also for long term widget
- 1.6.28 / .1 : new feature, showing forecast overview
https://uploadshub.com/tnbm5y26nf3c
https://filescdn.com/m5p2zd9n036e
https://uplod.it/bm3k3riqix4e
https://userscloud.com/3684b3sblaj5
01. 05. 2016 09:38
Meteogram widget - Donate v1.6.29.2
Bug fix: inconsistency between forecast overview and Beaufort
- 1.6.29.1:
Remove decimals from minimum and maximum temperature badges
Added Beaufort as wind speed unit
https://uploadshub.com/ne8tuko4qvk1
https://filescdn.com/kxm24itfapss
https://uplod.it/a5hej3fxxalh
https://userscloud.com/zvntosbko8gt
21. 09. 2016 19:58
Meteogram widget - Donate v1.7.3
Added advanced setting that forces update in portrait mode (may fix a scaling issue when the widget updates while running other apps (in landscape mode)).
- 1.7.2:
Bug fix: wind vanes did not show up correctly anymore in Android 7.0 (Nougat)
- 1.7 / 1.7.1:
New (optional) weather provider "Forecast.IO". This paid weather provider offers hourly forecast data worldwide. Notice that this provider can be activated by a 3-monthly subscription (which you can cancel at any time).
https://dailyuploads.net/7efzzmhyifxz
https://dropapk.com/7urzqeepxbs5
https://userscloud.com/1o7x9arhcol4
09. 10. 2016 12:43
Meteogram widget - Donate v1.7.4
v1.7.4:
Russian translation improvements
https://dailyuploads.net/p3bz0zg8rxil
https://dropapk.com/um0l9zyol9lh
https://userscloud.com/7lfwn3z2biet
05. 03. 2017 08:38
Meteogram widget - Donate v1.7.11
Co je nového:Fixing an (old) issue which could crash the widget while running other apps in the foreground.
https://play.google.com/store/apps/details?id=be.inet.rainwidget.donate&hl=en
https://ulozto.cz/!JTZzhTuOyctJ/meteogram-widget-donate-v1-7-11-apk
https://ulozto.sk/!d7ig1YCSKCJw/meteogram-widget-donate-v1-7-11-apk
https://ulozto.net/!PDMYDCLrDRjR/meteogram-widget-donate-v1-7-11-apk
https://webshare.cz/file/202Wv5v31x/meteogram-widget-donate-v1-7-11-apk
29. 07. 2017 04:08
Meteogram widget - Donate v1.8.1
44,-Kc
Co je nového:Fixed a bug occurring when using the DarkSky weather provider and Fahrenheit and / or inches as temperature / precipitation unit.
https://ulozto.cz/!8TuKkwavRwzv/meteogram-widget-donate-1-8-1-apk
https://webshare.cz/file/e811u2z74d/meteogram-widget-donate-1-8-1-apk
26. 08. 2017 09:44
Meteogram widget - Donate v1.8.2
Co je nového: Fix bug NOAA weather service (48H forecast was not loading).
https://ulozto.sk/!km4cBKIYMq35/meteogram-widget-donate-1-8-2-apk
https://webshare.cz/file/1ru4k06253/meteogram-widget-donate-1-8-2-apk
