09. 06. 2015 21:25
Auto Optimizer
Auto Optimizer v4.2.0
Popis: Aplikace pro optimalizaci systemu.
- na GP se k teto verzi neuvadi
Vice info:Kód: Vybrat vše
https://play.google.com/store/apps/details?id=jp.snowlife01.android.autooptimization
Stahuj zde:Kód: Vybrat vše
http://uloz.to/xjx8RvEG/auto-optimizer-v4-2-0-apk
- Auto optimize your device to keep it functional!
- Easy to use, highly effective, faster processing speed!
- Optimize instantly with just a tap on the home button. → Achieve a smooth operation on your device.
- Display memory and battery info on the status bar or overlay.
- Equipped with a powerful battery saver function. Battery life will be significantly improved!
- Equipped with functions to clear various histories and caches.
- Auto optimization execution condition and details can be set.
- Advanced settings are also available for display during execution.
- Optimize instantly with just a tap on the shortcuts.
- Realize the fastest possible processing speeds by eliminating unnecessary processes.
- Flexible settings to fit the way you use your smartphone, including detailed auto-executing conditional settings.
- Check detailed information about the state of your device, including the ability to display remaining memory.
You can check this app's functions and operations with a free trial.
Please check the functions and operations by free trial before you buy.
https://play.google.com/store/apps/deta ... tion.trial
[Memory release / Clear cache / Clear history]
- Execute when home button is tapped
- Execute when screen is turned off
- Execute by memory usage rate
- Execute at a set interval
- Manually execute with just a tap on the shortcuts
[Battery saver]
Depending on the device and the usage, the battery consumption can be reduced approximately by 1/10 to 1/3 while the screen is off.
[Display memory info]
Displays free memory size or free memory(in %) or used memory size or used memory (in %) on the status bar or overlay.
[Display battery info]
Displays remaining battery life on the status bar.
[Ultra memory release]
When free memory is very low, the Android system terminates running processes.
"Ultra memory release" function uses this method to release memory.
(Attention)
May not work properly depending on the specifications of the device or OS.
Also has various other useful functions.
■Recommended for those who:
- Want an automatic execution app
- Want to be able to set exclusion of memory release
- Want an app with a high memory release rate
- Want an app with a fast processing speed
- Want an app that execute with a single tap
- Want an app without advertisements
- Want an app for non-resident automatic memory release / clear cache
- Want an app for good battery life
- Want to display memory info on the status bar or overlay
- Want to display battery info on the status bar
■List of functions
- Memory release (task killer)
- Clear cache
- Clear history
- Resident type settings
- Auto-execute by memory usage rate
- Auto-execute at a set interval
- Auto-execute when screen is turned off
- Exclusion of memory release settings
- Clear history settings
- Sound effect of execution settings
- Display mode of execution settings
- Widgets
- Shortcuts to each functions
- Battery saver
- Ultra memory release
- Display memory info
- Display battery info
- Detailed device info
12. 11. 2017 13:49
Auto Optimizer v5.4.5 [Paid]
75,-Kc
4.0 a vyšší
Co je nového: Oprava týkající se popisu funkce aplikace.
https://www.ulozto.cz/!IVRVjf9eIzy8/auto-optimizer-5-4-5-apk
https://www.ulozto.sk/!Ejp2WnzROjup/auto-optimizer-5-4-5-apk
11. 11. 2018 17:55
Auto Optimizer v6.0.0 [Paid]
4.0 a vyšší
- Support android 9.
- Fixed bugs and improved functions.
https://upload4earn.org/iyue8k4539u1
https://douploads.com/xi0arf7h27ck
08. 03. 2020 17:16
Auto Optimizer v7.5.3 [Paid]
Požadavky: Android 4.1 a
vyšší
Novinky ve verzi: Některá drobná vylepšení.
https://uloz.to/file/QlJs6qtE00B3/auto-optimizer-v7-5-3-apk
https://ulozto.sk/file/53OLvZcJj1Kh/auto-optimizer-v7-5-3-apk
https://ulozto.net/file/YmasFYvrBkHF/auto-optimizer-v7-5-3-apk
https://webshare.cz/#/file/fe3ii1oC1P/auto-optimizer-v7-5-3-apk
10. 04. 2020 08:17
Auto Optimizer v7.6.0 build 233 [Paid]
vyšší
Novinky ve verzi: Přidána funkce automatického restartu. (Android 7.0 nebo novější).Automaticky restartujte zařízení v době, kdy jste nastavili, aby byl výkon zařízení optimální.
https://www.uploadship.com/441999a00f43409c
https://userupload.net/it00z2jlw89d
https://up-load.io/vy8ej4pglawm
http://ul.to/fzlr1rj4
https://mixloads.com/bvz279ixtfdo
13. 04. 2020 12:15
Auto Optimizer v7.6.3 build 238 [Paid]
vyšší
Novinky ve verzi: Opravené chyby s funkcí automatického restartu.
https://www.uploadship.com/26afbad5076b4d9d
https://userupload.net/ypxvli6kojbg
https://up-load.io/6dgsoqzju11k
http://ul.to/t4f8wrh9
https://mixloads.com/d3ur32ewyqzl
