9 příspěvků •Stránka 1 z 1
nPlayer PRO
Henry1
09. 09. 2009 07:54
05. 01. 2018 11:16
nPlayer PRO
nPlayer PRO v1.2.2.39_180102 Patched
Requirements : ↑4.0.3
Overview : nPlayer officially supports DTS (DTS HD ), DTS Headphone:X.
- You don't need to convert video files to MP4 to play them in your mobile device. nPlayer enable you to play all kinds of video formats and codecs without file converting efforts.
- You don't need to store video files in your device with limited storage space. nPlayer's powerful and various network technologies will help you to stream them from remote devices.
- With your finger tip, you can adjust playback position, move to previous and next subtitle position, adjust location and font size of subtitles, control volume and brightness.
- Experience nPlayer, thousands of users recommendations.
* Features
- Supports officially DTS audio codec (DTS HD)
- Supports Pop-up play
- Supports video cast for Smart TV
- Supports HDMI output
- Supports video files : MP4, MOV, MKV, AVI, WMV, ASF, FLV, OGV, RMVB, TP etc.
- Supports audio files : MP3, WAV, WMA, FLAC, APE etc.
- Supports subtitle files : SMI, SRT, SSA, IDX, SUB, LRC, SUP, MLP2 etc.
- Supports image files : JPG, PNG, BMP, GIF, TIFF etc.
- Supports playlist files : CUE, M3U, PLS
- Supports WebDAV, FTP, SFTP, HTTP, SMB/CIFS
- Supports UPnP/DLNA (supports subtitles if DLNA server provides subtitles information.)
- Supports cloud service (Amazon Cloud Drive, Box, Dropbox, Google Drive, OneDrive, Yandex.Disk)
- Playback speed control : 0.5x ~ 4.0x
- Resume playback
- AB repeat(specific section repetition)
- Screen lock
- Aspect ratio : Default, 1:1, 3:2, 4:3, 5:3, 16:9, 1.85:1 etc
- Supports multi-track audio
- Supports audio boost
- Supports audio sync
- Supports lyrics display
- Supports embedded subtitles
- Supports multi-track subtitles
- Supports user’s selection of subtitle files
- Supports subtitles font, color, shadow, outline customization
- Supports subtitles sync
- Supports external subtitle fonts
- Supports SAMI(SMI) tag
- Supports SSA/ASS with full styling, embedded subtitles
- File management : Delete, Move, Rename, Create a folder
- Playlist management : Add, Delete, Modify
- Supports recently played list
- Folder lock
* Gesture Features
- Tap : Menu
- Double tap : Pop-up play
- Drag horizontally : Playback position adjustment
- Drag vertically on right half of the screen : Volume control
- Drag vertically on left half of the screen : Brightness control
- Pinch on the screen : Screen size adjustment
- Drag horizontally on subtitle text : Move to previous/next subtitle text
- Drag vertically on subtitle text : Subtitle position adjustment
- Pinch on subtitle text : Subtitle font size adjustment
- Supports finger gesture customization
What's New :
v1.2.2.39
- Fixes the issue of screen aspect ratio
- Fixes the issue of subtitles folder
- Fixes the issue of subtitle track when switching to pop-up play
- Fixes ohter bugs and improves stability
Google Play :
https://play.google.com/store/apps/details?id=com.newin.nplayer.pro
Download :
https://ulozto.cz/!fh23AucqOI01/nplayer-v1-2-2-39-180102-apk
https://dailyuploads.net/f0u4ngesfpqf
https://douploads.com/bwfivahx4gg2
Henry1
09. 09. 2009 07:54
23. 09. 2018 19:06
Re: nPlayer
nPlayer PRO v1.4.7.2_180911 Patched
Requirements : ↑4.2
What's New :
v1.4.7.2
- Fixes and improves the audio passthrough issue
- Bug fixes and stability improvements
More Info :
Download :
https://uloz.to/!89Ej8sDYwJII/nplayer-pro-v1-4-7-2-180911-apk
https://upload4earn.org/j2ziie2cd15z
Henry1
09. 09. 2009 07:54
04. 04. 2019 05:07
Re: nPlayer
nPlayer v1.5.4.27_190118 Patched
Requirements : ↑4.2
What's New :
v1.5.4.27_190118
- Fixed Google Drive login under Android 4.4
More Info :
Download :
https://uloz.to/!sf4qGYOFw2wj/nplayer-v1-5-4-27-190118-patched-apk
https://dropapk.com/tjisc9gti30c
Henry1
09. 09. 2009 07:54
07. 04. 2019 05:07
Re: nPlayer
nPlayer v1.5.5.3_190228 Patched
Requirements : ↑4.2
What's New :
v1.5.5.3_190228
● Analytics Removed ●
More Info :
Download :
https://uloz.to/!flI52iW1dotI/nplayer-v1-5-5-3-190228-patched-apk
https://dropapk.com/ikaobedy9uf6
Henry1
09. 09. 2009 07:54
17. 04. 2019 14:04
Re: nPlayer
nPlayer v1.5.6.23_190415 Patched
Requirements : ↑4.2
What's New :
v1.5.6.23_190415
- Removes Send Anywhere due to partnership termination.
- Bug fixes and usability improves
● No Patcher Needed
● Analytics Removed
More Info :
Download :
https://uloz.to/!DJQvLSp0SnkX/nplayer-v1-5-6-23-190415-patched-apk
https://dropapk.com/4ske15s5hnn5
Henry1
09. 09. 2009 07:54
08. 07. 2019 10:04
Re: nPlayer
nPlayer v1.6.1.5_190626 Patched
Requirements : ↑4.2
What's New :
v1.6.1.5_190626
● No Patcher Needed
● Analytics Removed
More Info :
Download :
https://uloz.to/!aGJnWZNBZaIb/nplayer-v1-6-1-5-190626-patched-apk
https://dropapk.com/2egjw4t1l7h0
Henry1
09. 09. 2009 07:54
22. 10. 2019 11:35
Re: nPlayer PRO
nPlayer v1.7.3.7_191021 Patched
Requirements : ↑4.2
What's New :
v1.7.3.7_191021
- Supports Text-To-Speech for subtitles
- Supports for moving files on local
- Supports native 64-bit
- Supports in-app web browser
- Changes external codec to FFmpeg 4.2.1
● No Patcher Needed
● Analytics Removed
● AOSP Compatible
● EAC3 (DD+), TRUE HD Codec Supports
More Info :
Download :
https://uloz.to/file/bpXrAG4gSBqd/nplayer-v1-7-3-7-191021-patched-apk
https://dropapk.to/r7ztmvdo9y1s
31. 10. 2019 10:26
Re: nPlayer PRO
nPlayer v1.7.4.3_191030 [Patched][Mod]
130,-Kč
Požadavky: Android 4.2 a vyšší
Podpora pro celou obrazovku nPlayer v Samsung Dex.Opraveny další chyby.
Stahuj zde: armeabi v7a:
https://www.uploadship.com/7c48d0f2a37f6ccf
https://dropapk.to/iivzh7lmmzf8
https://upload.ac/9lih8f1fux16
https://mixloads.com/b6yrqvc8cudv
https://uloz.to/file/NsGm0S3ateHE/nplayer-v1-7-4-3-191030-patched-mod-apk
Stahuj zde: arm64-v8a:
https://www.uploadship.com/0540e3f21b89ccef
https://dropapk.to/7cwiwiw161ud
https://upload.ac/3o5d6sk9zpw6
https://mixloads.com/zpjt92nfpv7a
22. 12. 2019 18:23
Re: nPlayer PRO
nPlayer v1.7.7.7_191219 [Modded]
130,-Kč
- Podpora zvukového mini přehrávače.
- Podpora nastavení barev uživatelského rozhraní přehrávání.
- Podpora změny pořadí playlistů
- Podpora nastavení zástupců.
- Důležitá stabilita.
Stahuj zde: armeabi-v7a:
https://www.uploadship.com/f93bf81a34accaab
https://dropapk.to/g7v5yxajamdz
https://upload.ac/2vr5awxc2gqp
https://www.uploadship.com/53635380889a5ad6
https://dropapk.to/zcdaznod12k3
https://upload.ac/42nvj1f2nag0
https://www.uploadship.com/dbd2189553ef908e
https://dropapk.to/xisp444a2ktj
https://upload.ac/socn8zp2x7tt
https://www.uploadship.com/cca03c4cbe200196
https://dropapk.to/m09doydhlp6k
https://upload.ac/jzefl55memn6
