17. 05. 2018 18:54
Chrooma Keyboard PRO Swipe,Type, Gestures vhydrogen
Chrooma Keyboard PRO - Swipe, Type, Smart Gestures vhydrogen-1.6 [Pro]
5.0 a vyšší
Popis:Klávesnice Chrooma je poháněna inteligentní umělou inteligencí, která vám poskytuje lepší kontextové předpovědi.
https://play.google.com/store/apps/details?id=com.gamelounge.chroomakeyboard
https://uloz.to/!MFv6m3dpPkX3/chrooma-keyboard-pro-vhydrogen-1-6-apk
https://ulozto.sk/!13hKSug3DhF1/chrooma-keyboard-pro-vhydrogen-1-6-apk
Chrooma Keyboard is a lightweight, fast keyboard that adapts its color to the app you are using.
According to AndroidAuthority.com Chrooma Keyboard is "the best Android app released in all of 2016"
Chrooma has a new exclusive neural action row that helps you with emojis , numbers and punctuations suggestions !
And if emojis are not enough for you, with Chrooma Keyboard you can search and send all the GIF you want!Chrooma Keyboard always fit your style thanks to its high level of personalization (themes, font styles, emoji styles, keyboard size.But Chrooma Keyboard is not just a beautiful keyboard it's also a smart productivity tool.These are just some of the most cool features you will find in Chrooma Keyboard :
GIF search
With Chrooma Keyboard you have a dedicate GIF tab to search and send all the GIFs you want! Chrooma's GIF are supported by almost every app.
Emojis Support
Our keyboard supports automatic emojis suggestion and helps you by providing you your most used emojis .
Chrooma is always updated to support the latest emojis available.
Colored Navbar
Chrooma Keyboard automatically changes the color of your navbar according to the app you are using Dotazy na SZ.
18. 05. 2018 12:11
Chrooma Keyboard PRO - Swipe, Type, Smart Gestures vhydrogen-1.6.3 [Pro]
5.0 a vyšší
Co je nového:Opravy a vylepšení chyb.
https://uloz.to/!kLYvLY2cMcs4/chrooma-keyboard-pro-vhydrogen-1-6-3-apk
https://ulozto.net/!cXuQShBda0xL/chrooma-keyboard-pro-vhydrogen-1-6-3-apk
13. 07. 2018 16:23
Chrooma Keyboard PRO - Swipe, Type, Smart Gestures vhydrogen-1.9.1 [Pro]
5.0 a vyšší
Co je nového:- YOU CAN NOW CUSTOMIZE THE KEYPRESS SOUND
- Settings design improvement
- Bug fix and performances
https://uploadocean.com/2cx2xr4xl5lq
https://upload4earn.org/9ycc89cq5knf
http://katfile.com/egb4q826djdo
https://douploads.com/x4q6euor5pek
http://ul.to/w3ok0je3
https://usersdrive.com/pkaexsd9cjyj.html
https://uloz.to/!VREM7CjxbcvE/chrooma-keyboard-pro-v1-9-1-apk
23. 07. 2018 17:07
Chrooma Keyboard PRO Swipe, Type, Smart Gestures vhydrogen-1.9.6 [Pro]
5.0 a vyšší
Co je nového:- The keyboard is so personalizable that we had to implement a search engine to navigate efficiently the settings,
(it's now available only in english, will be soon translated in every language)
https://uploadocean.com/mjkjpgdpj1mo
https://upload4earn.org/vprbj984an9q
http://katfile.com/3vc923h6zzqu
https://douploads.com/0snkxomvfeap
https://usersdrive.com/bncsb2szqb9u.html
http://ul.to/7nqbwt43
