17. 05. 2018 21:33
Video To MP3: Mute Video /Trim Video/Cut Video
Video To MP3: Mute Video /Trim Video/Cut Video v1.7 [Pro]
4.0 a vyšší
Popis:Převést libovolný video soubor do souboru zvuku ve formátu MP3. Odstranit zvuk z videa (Vytvořit ztlumení videa). Trim Video jakéhokoli formátu, velikosti a trvání se stejnou kvalitou Výstup
https://play.google.com/store/apps/details?id=com.andromania.videotomp3&hl=en
Stahuj zde: Pro features unlocked
https://ulozto.sk/!Wnri5gXUXjeS/video-to-mp3-1-7-apk
https://ulozto.net/!WgYhV5OOHgN9/video-to-mp3-1-7-apk
Convert any Video file to Audio file in Mp3 format. Remove Audio from Video(Create Mute Video). Trim Video of any format, size & duration with same quality Output.
No hidden cost. App is free to use.
Features-
* Convert Video to Mp3 - Extract Audio from Video of any format and save as Mp3 file in your device.
* Mute Video- Wanna remove sound from Video? Use this app to Mute Video and remove unwanted Audio from your Video.
* Trim Video- Easily select the part of Video you wanna trim and get same quality output Trimmed Video.
* Supports Video formats including MP4, WMV, 3GP, AVI, MPG, M4V, MPEG4, MOV, MKV, WEBM, M2V, etc.
* Best Quality Output.
* Fast Processing. Mute and Trim video in approx. no time. Fast Video to Mp3 Conversion.
*Easy to use with Intractive UI.
* Output Gallery to see created output files. Share and Delete output files easily. Dotazy na SZ.
24. 07. 2018 22:34
Video To MP3: Mute Video /Trim Video/Cut Video v1.11 [Pro]
4.0 a vyšší
Co je nového:Bug Fixed and Improved UI
Feature:-
1. Added accurate video trim.
2. Added mute without trim video(only selected part video will be mute).
3. Added mute with trim video.
4. Added meta data change.
https://uploadocean.com/cflfbkyhdr4j
https://douploads.com/2fioa43dfr2a
