18. 05. 2018 17:16
AVG Cleaner Speed, Battery & Memory Booster
AVG Cleaner Speed, Battery & Memory Booster v4.6.0 [Pro]
S nástrojem AVG Cleaner bude vaše zařízení Android pracovat rychleji a hladce, ukládat více dat, uvolní paměť vyčištěním nevyžádané pošty a baterie zůstanou nabité delší dobu.
https://play.google.com/store/apps/details?id=com.avg.cleaner
https://uloz.to/!80mBU3eFgkOq/avg-cleaner-pro-3-1-0-1-apk
https://ulozto.sk/!F4UDOMrDTmWH/avg-cleaner-pro-3-1-0-1-apk
Cleaner: Advanced app remover & app manager:
► Remove preinstalled apps: Do you have pre-installed bloatware apps you don't need? We can prevent them from slowing down your device
► App analyzer: AVG Cleaner can identify apps that consume your battery, drain mobile data, or take up too much storage space, allowing you to clean them out more easily
► App remover: Easily remove apps that slow down your device
► Easily analyze apps based on storage, ram, battery, data consumption or usage
Cleaner: Photo Analyzer:
► Fast and easy photo gallery optimization
► Find bad quality or duplicate photos
► Our 'swipe left to delete, swipe right to keep' feature helps you decide if you want to remove or keep the identified photos
Cleaner: Battery Saver & Optimizer:
► App hibernation: Hibernating apps help you prolong battery life and keep your device running faster for longer
► Battery Profiles & Optimization: choose between "Low Battery", "Home", "Work", and "Car" profiles, or set up your own to automatically adjust your battery usage how you want (30-day FREE trial)
Cleaner: 1-tap Analysis and Optimization
► Clean your device with a single tap of a button
► Perform device scan and analysis with just one tap
Naposledy upravil(a) milann70 dne 10. 03. 2019 15:51, celkem upraveno 1 x.
22. 02. 2019 16:34
Re: AVG Cleaner Speed, Battery & Memory Booster
AVG Cleaner Speed, Battery & Memory Booster v4.10.1 [Pro]
Co je nového: Obrázek
- Vylepšeno pro nejnovější verze systému Android
- Zjednodušené povolení udělení toků
- Přidána možnost obnovit výsledky analýzy skladování
- Výrazně zlepšená stabilita
https://www.file-upload.com/06e9dpnoxgvu
https://upload4earn.org/picmix0jqbdg
https://douploads.com/ojhyx2a4aodb
https://uploadbuzz.org/36fcwvukb13h
http://ul.to/gkw1bwz2
10. 03. 2019 15:55
AVG Cleaner Speed, Battery & Memory Booster v4.12.2 [Pro]
This update is all about technical improvements. We focused on faster startup and increased the reliability of hidden cache cleaning so it is as effective as possible on all supported devices.
https://douploads.com/3czj1qnojzwi
https://upload4earn.org/fxnrua72d7xj
https://dropapk.com/j4cp7iteys58
https://speed4up.com/sq6hdjhsxcf2.html
https://upload.ac/4q3rng89l7dz
http://ul.to/rufry0qk
21. 03. 2019 11:34
AVG Cleaner Speed, Battery & Memory Booster v4.12.3 [Pro]
Se zařízením AVG Cleaner bude vaše zařízení Android běžet rychleji a plynule, bude ukládat více dat, uvolňovat paměť čistěním nevyžádané pošty a baterie zůstane déle nabitá.
https://dropapk.com/xmxvdwqm5kac
https://upload4earn.org/c0er237qhjl7
https://douploads.com/q6t3a018zvro
https://speed4up.com/cgjltqn1lgn0.html
http://ul.to/g2nenupr
15. 04. 2020 17:23
AVG Cleaner Speed, Battery & Memory Booster v4.21.0 [Pro] [Mod] [SAP]
Automatické profily baterií (prémiová funkce) jsou nyní mnohem vylepšeny díky dalším akcím a podmínkám založeným na poloze, zbrusu nové uživatelské rozhraní.
Mod Info:
Standalone Android Package;
Android App Bundle Repacked (Split APKs Packer v5.3.3 by KirIif'):
• Supported CPU architecture: armeabi-v7a, arm64-v8a;
• Supported Screen DPIs: ldpi [120dpi], mdpi [160dpi], hdpi [240dpi], xhdpi [320dpi], xxhdpi [480dpi], xxxhdpi [640dpi];
• Languages: Multi Languages;
Professional features unlocked;
No startup with Promo page;
Promo Apps disabled;
Disabled / Removed unwanted Permissions + Receivers and Services;
Analytics / Crashlytics disabled;
AOSP compatible.
https://www.uploadship.com/531b5d29e3db4c62
https://intoupload.net/jlf0aczx8fub
http://ul.to/68kcce3o
https://webshare.cz/#/file/uVHVCzDQwH/avg-cleaner-pro-v4-21-0-mod-apk
02. 07. 2020 19:03
AVG Cleaner Speed, Battery & Memory Booster v4.22.0 [Pro] [Mod] [SAP]
Automatické profily baterií (prémiová funkce) se nyní mnohem zlepšují díky dalším akcím a podmínkám založeným na poloze, zcela nové uživatelské rozhraní.
Mod Info:
Android App Bundle Repacked (Split APKs Packer v5.5.1 by KirIif'):
AOSP compatible.
https://userupload.net/vqfytnyfvxx6
https://www.uploadship.com/018675ecfceedb53
http://ul.to/nxlp1ars
https://up-load.io/ax8kf08qij00
https://mega4up.com/6g276dn77el0
https://www.file-up.org/i3tjbb4xos49
