10. 07. 2018 13:11
Magnifier, Magnifying Glass with Flashlight Premium
Magnifier, Magnifying Glass with Flashlight Premium v3.5.4
liší se dle zařízení
Popis:Are you tired of trying to read some labels with small fonts? Now you can use your android device as the perfect digital magnifier.
https://play.google.com/store/apps/details?id=mmapps.mobile.magnifier&hl=en-GB
Stahuj zde: Premium features unlocked
ttps://dailyuploads.net/0m2y1jvrnb4q
https://douploads.com/v1u1iqf3yvds
There is not need to take a magnifying glass when reading small labels, with this app you will see the text big and clear.Magnifier has onscreen zoom and lighting controls so you can change it easy, you can also use your flash as torch in order to get a better image, or activate the negative color mode.There is also a freeze image functionality that will let you freeze the image so you can read it comfortably. Once you freeze the image, you can save it or share it if you want.Try this app now and stop worrying about text you can't read!
Key features:
✓ High magnification factor
✓ Zoom and Exposure controls
✓ Flashlight for low light situations
✓ Negative mode
✓ Freeze, save or share images
✓ Awesome image visibility
✓ Really simple to use Dotazy na SZ.
