IP Tools is a powerful network toolkit for speed up and setup networks. It allows quick detecting any computer network problems, ip address detection and boosting network performance.
The app combines the most popular network utilities usually found in desktop PC. They will help you fix a network problem easily or optimize the network when you are hundreds of kilometers away (i.e. not at work IP Tools has a simple, intuitive interface, so you can receive within seconds full information on your network, find out internal or external IP (with "My ip" feature), SSID, BSSID, broadcast address, gateway, network mask, country, region, city, the provider’s geographical coordinates (latitude and longitude), whois and other basic information.The IP Tools app provides access to the most popular network utilities that administrators and users often use on their computers.
• Ping
• LAN Scanner
• Port Scanner
• DNS Lookup
• Whois - Provides information about a website and its owner
• Router Setup Page
• Traceroute
• WiFi Analyzer
• IP address with "My ip" feature
• Connection Log
• IP Calculator
• IP & Host Converter
• And much more...
WiFi analyzer will help you get full and clear picture of your network state. With IP Tools, analysis and optimization are fast, easy and absolutely friendly. The app is improved continuously. Its developers allow for customer opinions and modify the product offering new, more functional and handy versions.
The app’s benefits go far beyond the above list. However, even those mentioned are enough to dismiss doubts, download the IP Tools network utilities to your smartphone and assess advantages from using them right now.
