47,-Kč
Popis: Aplikace, která automaticky nastaví uživatele do prostředí, které jste nastavili při spouštění a vypínání aplikací.
https://play.google.com/store/apps/details?id=com.kmshack.autoset
https://upload4earn.org/t01nknaq5qxp
https://uploadocean.com/fjd2fj1kxo14
http://cloudyfiles.me/y7nmo43diwfp
https://douploads.com/mdxzhkrzgzou
http://speed4up.com/458c56689b15ca23
http://ul.to/l2wlxbhf
** main function
- Time setting function with scheduling notification setting
- Ability to change the settings to the environment that the user set by monitoring the execution of the application
- WiFi and BT connection settings
- Screen Brightness, Rotation Direction, Auto Screen Off Time Setting
- Sound size, sound mode can be set
- Automatic termination and retention of other app conversions during app launch
* When do you use it?
- You can prevent Wi-Fi from wasting your mobile data by automatically turning on Wi-Fi when you run the YouTube app.
- When you run Navigation, you can automatically make the screen brighter and sound louder.
- You can also set the sound to be smaller automatically when you play the game.
- You can set it to landscape mode automatically when you launch a specific app.
- You can also set Bluetooth to turn on automatically when you run music app.
- It is possible to switch to silent mode automatically at work time.
