27,-Kč
Popis:Prefer using folder to manage your music files?
https://play.google.com/store/apps/details?id=com.dp.ezfolderplayer
https://uploadocean.com/mgdekc3r36hm
http://cloudyfiles.me/wbiwqb9amewh
https://douploads.com/kquonmv0slwk
http://ul.to/lhoybio7
• Very efficient, fast and good performance.
• high-speed search options
• Search filters - search for suffix, prefix(starts with, ends with)
• Voice recognition
• Works offline
• You can add marked words to the favorite list
• Creating bookmark and adding words to bookmark list
• Keeping of Looked-up words in history( as day,month ...)
• Sharing in other apps
• Sounding of word or marked text (Text-to-speech engine)
Description window is opened as clicking on the word. You can minimize and maximize the description window with swipe function.
• The option of searching, sounding and sharing of marked word in the description window.
• Description of selected word are opened on the same window.
• Tablet UI Support
- Setting
• Changing option of text size
• Changing option of UI color
• Clearing option of Bookmark, Favorite, History list
• You can change the size of text with clicking on down/up volume buttons.
• You can change the color of UI with double clicking on down/up volume buttons.
• You can change description view position on landscape mode (description view on left/right)
