(20,- Kč)
Pozadavky: Android 6.0 a vyšší
Popis: Trekarta (former MapTrek) is designed for hiking, geocaching, off-roading, cycling, boating and all other outdoor activities.
• Added ruler to measure distances.
• Added options to share and remove private maps.
• Added ability to move application data to user storage root folder to prevent data loss on application uninstall. Added ability to move application data to SD card to free device storage space.
• Fixed keyboard issues on Android 8 (Oreo).
• Fixed maps download while in background on Android 8 (Oreo).
• Fixed large size map download.
https://play.google.com/store/apps/details?id=mobi.maptrek
https://webshare.cz/file/2fr4Wr4ro1/trekarta-offline-maps-for-outdoor-activities-v2018-12-build-63-paid-apk
http://speed4up.com/deqgk1g67ojl.html
https://upload4earn.org/jtw33dxkabex
https://uploadev.com/dlmmwkwxgpgk
https://douploads.com/e3rant9viveq
https://uploadbuzz.org/g22rxyb0it9x
http://ul.to/tn7rzscc
Offline maps
Trekarta uses OpenStreetMap based vector maps that are lightweight, offline and are constantly enhanced by contributors. Maps contain detailed topological data with elevation contours. Some map elements can be filtered out for cleaner look. Trekarta has built-in hillshades support. You can add custom maps in sqlite or mbtiles format to cover your area of interest. Custom maps will be shaded as well. Such maps can be created by yourself with SAS.Planet application from mostly any online source or converted with MapTiler and other applications from other map formats.
Hiking
Special hiking activity mode emphasises paths and tracks on map. It visualizes path difficulty and visibility and displays hiking routes. It also displays special OSMC symbols that help you identify desired route.
Skiing and skating
Skiing activity mode displays clean winter map with mostly all skiing activities: downhill, nordic, hiking and touring. As a bonus freestyle snow-boarding, skating and sleighing areas are displayed.
Off-road
Unpaved, dirt, winter and ice roads are specially visualized. 4wd only roads have specific marking. Fords are displayed on all roads, even primary.
Places
Places can be easily imported from GPX and KML files or can be created within application. You can navigate to places and share them with others.
Tracks
Trekarta is designed to record tracks of your journey. Simply press a button when you start and press it once more when you finish. You can quit the application if you do not need to look at the map, the track will be recorded in the background.
Plugins
Trekarta functionality can be extended by plugins. Currently the following plugins are available:
• Location sharing
• Dropbox sync
