Popis: Screen Recorder je rekordér obrazovky bez root aplikace pro záznam a zachycení mobilní obrazovky ve formátu videa s nebo bez přední kamery.
https://play.google.com/store/apps/details?id=com.ezscreenrecorder
https://upload4earn.org/fp3qsv4ez8p8
https://douploads.com/15oosx99eozb
https://uploadproper.com/du2asaaprvc9
★ Using the front camera (facecam) will help you capture your own video and also the mobile screen recording at the same time. This option is best for recording the tutorials of any app. This feature is helpful for app developers to record the video to explain the usage of their applications.
★ Now draw and create tutorials with a whiteboard screen.
★ This mobile app screen recording feature is helpful for the users/ quality testers/ app testers to explain the problem they are facing in a particular app.
★ Screen recording of any app available on your mobile device can be done in live application usage mode, like typing any message, record video calls, viewing any video or listening to any audio or anything available on the mobile screen can be recorded.
★ This high-quality screen recorder for Android can be useful to the parents for monitoring the usage of mobile by kids by mobile screen recording.
★Draw text on screen while recording and trim videos with in-built video editor and recorder.
★ Screen recorder HD app doesn’t use any data/ internet, as we don’t upload any recording to any cloud network or server. All the videos are recorded and saved locally on phone/SD card memory.
★ Users can create story telling presentations, videography of still pictures with help of this Screen Recorder tool and can upload it on video streaming cloud.
★ App user has the choice to share it through Facebook video, youtube, email, Bluetooth or any other sharing mode.
★ Game users can record their gaming round while playing with Screen Recording video option in our app.
★Screen recorder for Youtube video recorders, content creators and App Reviewers/ Recorders can use this easy free tool for creating high-quality HD videos and later upload and monetize the content on their own video channels. Upload the captured videos as Youtube tutorials on your youtube account. It's FREE to upload videos to your youtube account.
★ This Screen recorder no root app uses Video compression algorithm for sharing to reduce your data bill and internet use.
★ This is the FREE app without any restriction to record screen and capture screenshots of your mobile screen. We allow the recorders to choose the options
• Quality of resolution of the Video format
• Option to set the Frame rate of the video to be recorded
• Option to set the Bit rate
• Option to choose the orientation as Portrait or Landscape video
• Option to choose whether the Audio recording to be done or not
• Option to enable or disable video compression
★ You can record long videos without worrying while saving on External Memory (SD Card)!
★ Home screen navigation shortcuts allow you to easily start recording and capturing screen.
★ You can also capture screenshots with this tool.
★ App Marketers and Digital Marketing can use this tool to create the video presentations, tutorials. The front camera can make it really much more interactive.
★ Recording of Mobile screen can be done with front camera feature which allows you to capture your expression for a perfect tutorial.
★ This app allows screen recording with audio even without the front camera or with the front camera of your mobile as per your choice.
★ Easy & Fast access to screen recording controls from Notification bar to ensure the screen recording is fast and quick for users.
