10. 02. 2019 15:21
FK Kernel Manager for all devices & Kernels [Patched]
FK Kernel Manager for all devices & Kernels v3.12.1 [Patched]
110,-Kč
5.0 a vyšší
Popis: A beautiful Kernel manager with a rich feature set aimed for easy of use! From the less knowledgeable, to the most expert user, it combines a series of powerful tools to manage and control your device.
https://play.google.com/store/apps/details?id=com.franco.kernel
https://douploads.com/fa1qn4d9ubpa
https://upload4earn.org/zzntbl2oa55u
https://dropapk.com/3j0syvysf97n
https://speed4up.com/e3b4nvsiwkni.html
https://uploadbuzz.org/g04m7xul7sji
http://ul.to/hkd4vttq
This app is device agnostic and it'll work regardless of the device/Kernel comabination you're using, but to access some specific features you'll need to be on Franco Kernel.
Also you need to be ROOTED otherwise nothing will really work.
Franco Kernel supports the devices below:
Galaxy Nexus
Nexus 4
Nexus 5
Nexus 5X
Nexus 6
Nexus 6P
Nexus 7 2012
Nexus 7 2013
Nexus 10
One Plus One
One Plus X
One Plus 2
One Plus 3
One Plus 3T
One Plus X
Google Pixel
Google Pixel XL
Redmi Note 3
Supports Android from JellyBean (4.1) up to Nougat (7.1.+) including LineageOS.
• Simple and elegant
• Deep integration with Franco Kernel;
• Checks for new Franco Kernel versions (with a choice for automatic daily checks);
• Auto flash Kernels directly into the device with a simple touch;
• Powerful battery saving tips as simple as touching a button;
• Display color temperature presets;
• Automatic High Brightness Mode toggle based on the ambient light (device support dependent);
• Download .zips to be flashed in recovery;
• Beautiful UI following Material Design guidelines;
• Interface to change CPU clocks, governor and other common interfaces pending Kernel support;
• Interface to change the CPU governor parameters;
• Backup & Restore Kernels on the fly in a single tap and frictionless;
• Custom Kernel settings such as: IO scheduler, IO scheduler tuning, certain wakelocks (if exposed by the Kernel) and other misc settings;
• A powerful tool called Per-App Profiles which lets you create power profiles for your favourite apps. For example you want maximum CPU frequency when gaming, but low frequency when reading an e-book. You can also choose whether for Wi-Fi to be on/off, if you desire you toggle Android Battery Saver, specify what type of Location Mode you want to use for that specific app and choose the display resolution on a per-app basis too: Available resolutions are: 540p, 720p, 1080p, 1440p and 2160p! The possibilities are endless and opens a lot of doors. You control the device, the device doesn't control you;
• A System Monitor with a beautiful UI courtesy of the developer Christian Göllner;
• A simple File Manager to flash boot.imgs and Kernel .zips on the go from anywhere inside the sdcard (open, delete and see info about the file);
• Color and Sound control for selected devices with Kernel support;
• Automatic Night Shift just like iOS to tint your display in orange/red to ease your eyes during the night;
• CPU temperature available in the notification bar for devices that export the CPU temperature;
• Performance Profiles built-in on Franco Kernel (Power-save, Balance and Performance) which you can select with a single touch, no need to mess with settings. Also features a Home screen widget for an easy way to change profiles without going into the app;
• Launcher Shortcuts for Performance Profiles;
• Quick Tiles for Performance Profiles;
• Specific Tasker intents for performance profiles automation;
• And there's a lot more to discover!
* Translated to Dutch, Hindi, Kannada, German and Chinese Simplified (and more to come). Dotazy na SZ.
21. 03. 2019 22:32
FK Kernel Manager for all devices & Kernels v3.12.8 [Patched]
31,-Kč
5.0 a vyšší
1. Added WQ Power Efficient, dirty expire centisecs, min free kbytes, extra free kbytes, oom kill allocating task, overcommit ratio and laptop mode options to Kernel Settings
2. Fixed a rare crash
https://douploads.com/whx4faarcv2t
https://upload4earn.org/8iksah9pyd9b
https://dropapk.com/oi3d5nh9i1rr
https://speed4up.com/m1dks0pugs7k.html
http://ul.to/swbljctj
24. 08. 2019 18:15
FK Kernel Manager for all devices & Kernels v4.3.3 [Patched
100,-Kč
Požadavky: Android
6.0 a vyšší
1. Další vylepšení back-auto-flash díky osm0sis.
2. Opraveno několik pádů.
https://www.uploadship.com/bf64e3d22fa66608
https://uploads4u.net/2oqpszb1rnsq
https://uploadrar.com/iwm59k0klni9
http://ul.to/gx10sr8o
https://upload.ac/mdfb8xra6gmd
18. 11. 2019 21:10
FK Kernel Manager for all devices & Kernels v4.7.7 [Patched]
100,-Kč
Požadavky: Android
6.0 a vyšší
1. High brightness mode support for Pixel 3, 4, OP7/7T/7 Pro/7T Pro;
2. Added HBM, display density and custom resolution to Per-app profiles;
3. Improved battery life tips layout;
4. Improved amp and wattage reliability;
5. Fixed battery monitor stats reset on %;
6. Added custom idle drain % warning;
7. Improved Dashboard layouts;
8. Improved reliablity when changing cpu freqs;
9. Fixed a ton of user reported issues;
10. & lots more!
https://www.uploadship.com/60e9a9bc3af43540
https://mixloads.com/2qgntytcv3rq
https://dropapk.to/odgyw4zwv1zp
https://webshare.cz/#/file/3K320tu86l/fk-kernel-manager-v4-7-7-apk
08. 01. 2020 19:19
FK Kernel Manager for all devices & Kernels v4.8 [Patched]
100,-Kč
Požadavky: Android
6.0 a vyšší
1. Přidán editor build.prop. Funguje i na novějších zařízeních typu root-root;
2. Přidán volitelný dar „Podporovatel 2020“;
3. Opravena podpora laditelných regulátorů na některých zařízeních;
4. Oprava pevných dialogů;
5. Lepší podpora cpusetů;
6. Nyní můžete přejmenovat skripty;
7. Aktualizováno binární pole busyboxu z osm0sis;
8. Mnoho oprav a drobných vylepšení napříč deskou.
https://www.uploadship.com/a997cdc292d48a9e
https://uploadrar.com/fbp7efe7lgdg
https://www.file-up.org/m85whxrtnrm7
https://dropapk.to/cucs6smeri3s
https://webshare.cz/#/file/5l6df5kwzB/fk-kernel-manager-v4-8-4allmobile-cz-apk
