13. 04. 2019 13:02
4G WiFi Maps & Speed Test. Find Signal & Data Now
4G WiFi Maps & Speed Test. Find Signal & Data Now v5.56.3 build 1600021
4.1 a vyšší
Popis: S OpenSignal můžete mapovat mobilní pokrytí, najít Wi-Fi hotspoty, otestovat a zlepšit příjem a získat rychlejší data.
https://play.google.com/store/apps/details?id=com.staircase3.opensignal
https://douploads.com/ymexkxj6bvea
https://upload4earn.org/y3b4sw1wlj4n
https://dropapk.com/mswkef3lappa
https://speed4up.com/zhkj4imeldga.html
https://upload.ac/i8kq45optm7t
http://ul.to/mr7tysek
✓ Signal compass points you in the direction your signal is coming from, just walk towards it!
✓ WiFi map allows you to easily locate nearby public networks.
✓ Coverage maps allow you see the best/worst places for signal.
✓ Speedtest feature allows you to see the true speed of your connection (download, upload & latency)
✓ NetworkRank shows which carrier is best in your area.
✓ See local cell towers.
✓ Free and ad-free
You can also:
✓ Help improve our crowdsourced and impartial maps by contributing data.
✓ Share your findings and compare your connection with other users.
✓ View your history of signal readings.
✓ test upload, download and latency
✓ Save your data to SD card.
✓ Signal booster for compatible phones
SMS Permission required to count the number of SMS sent to track your usage, SMS are never read (use a packet sniffer to check!)
Phone settings permission allows network reset on certain Android versions
Based on our community-generated data we are able to help keep you better connected by giving you a practical solution to the problems of slow mobile internet and dropped calls. Simply follow our signal compass to walk towards better phone signal or see our in-app coverage maps to work out which carrier is best for where you are, useful if you're thinking about changing. Our wifi maps help you find local public-access wireless networks (WAPs).
The Stats tab helps you to keep track of your usage, so there’s no danger of you going over your plan limit on data, voice or text. (NB – this is why the app needs permission to access contacts and SMS, these are the permissions needed to count calls and texts, messages are never accessed or read!).
Maps not updated in real-time. Don’t worry though, we log the information you share with us to improve our coverage maps and signal information. We’re working hard to make sure the data you contribute to the project is available to everyone as quickly as possible.
Tips:
- Not all towers and wireless routers are in our database - we’re working on it!
- Verizon & Sprint (CDMA) users will see only one connected tower at a time
- Moving in the direction of your cell tower (the signal compass) will not always improve reception due to interference effects/local geography.
Advanced notes:
- For GSM, cell tower are identified via cell id and location area code (CID and LAC)
- For CDMA cell towers are identified via Network ID, Base sub-station ID and system ID (NID, BSSID and SID). Dotazy na SZ.
28. 04. 2019 05:59
4G WiFi Maps & Speed Test. Find Signal & Data Now v5.57.1 build 1600023
4.1 a vyšší
Aktualizace pozadí.
https://douploads.com/6ah76hb5a323
https://upload4earn.org/awphyri29kso
https://speed4up.com/uq1q98cakrsq.html
http://ul.to/hqq7bj7g
https://uploadrar.com/d9jffx5pozu5
30. 03. 2020 14:40
OpenSignal 3G, 4G & 5G Signal & WiFi Speed Test v6.6.1-1 build 6006012
Požadavky: Android 4.1 a
vyšší
Opravy chyb a vylepšení výkonu.
https://www.uploadship.com/eca6c192c90f948d
https://uploadrar.com/787r7vvjfa6m
http://ul.to/la2m8dge
https://webshare.cz/#/file/5551Gh33n2/opensignal-6-6-1-1-b6006012-apk
11. 05. 2020 20:09
OpenSignal 3G, 4G & 5G Signal & WiFi Speed Test v6.7.2-1 build 6007022
vyšší
https://www.uploadship.com/82c52b2974558e51
https://userupload.net/opdbxlkfmsj5
https://uploadrar.com/ewtei08ukgjy
http://ul.to/cn0rgt58
https://ulozto.sk/file/kZRduiETzI7E/opensignal-6-7-2-1-apk
https://webshare.cz/#/file/i67tzh2vwN/opensignal-6-7-2-1-apk
18. 05. 2020 12:38
OpenSignal 3G, 4G & 5G Signal & WiFi Speed Test v6.8.1-3
Požadavky: Android: 4.1 a
vyšší
https://www.uploadship.com/2e8de73e60719360
https://userupload.net/8yrjc8axb5t0
https://uloz.to/file/bHdUinfz0Y5S/opensignal-6-8-1-3-apk
https://webshare.cz/#/file/d9JRxb5mM1/opensignal-6-8-1-3-apk
24. 06. 2020 05:10
OpenSignal 3G, 4G & 5G Signal & WiFi Speed Test v6.8.4.1
vyšší
https://www.uploadship.com/1c9a0f9b22b90d1f
https://userupload.net/sxxqwabx8uvk
https://webshare.cz/#/file/j3w5srgB08/opensignal-6-8-4-1-4allmobile-eu-apk
07. 07. 2020 13:12
OpenSignal 3G, 4G & 5G Signal & WiFi Speed Test v7.1.2-2
vyšší
OpenSignal se stává Opensignal! Stejná aplikace, stejné skvělé funkce, jednoduše aktualizujeme název aplikace tak, aby odpovídala názvu naší společnosti, Opensignal, a lépe odrážela naše poslání: budování nezávislého zdroje pravdy pro mobilní zážitky po celém světě!
Kromě této aktualizace obsahuje toto vydání také řadu vylepšení designu a několik oprav chyb.
https://userupload.net/5z7zx0luqftq
https://uploadrar.com/hq314fuplxel
https://dropgalaxy.in/xyf96v4ypend
https://uloz.to/file/daA4lViySQZT/open-signal-4allmobile-eu-apk
02. 08. 2020 19:56
OpenSignal 3G, 4G & 5G Signal & WiFi Speed Test v7.3.1-1
vyšší
OpenSignal is becoming Opensignal! Same app, same great features, we're simply updating the name of the app to align with our company's name, Opensignal, and better reflect our mission: building an independent source of truth for mobile experience worldwide!
In addition to this update, this release also includes a number of design improvements and several bug fixes.
https://userupload.net/alrjfcuaqs9i
https://uploadrar.com/4m0mmrjmn1kv
https://dropgalaxy.in/cxbo9gkdexn6
https://webshare.cz/#/file/TjIyvZwVs8/open-signal-4allmobile-eu-apk
