Popis: Relax Melodies Meditace je ideálním pomocníkem, který vám pomůže vytvořit prostředí relaxace a meditace bez ohledu na místo nebo čas!
https://play.google.com/store/apps/details?id=ipnossoft.rma.oriental
https://douploads.com/5qzmzfc70fqa
https://upload4earn.org/7490kf8id4d2
https://speed4up.com/pwku7bu7mge0.html
https://upload.ac/pbi2pt9udjqv
http://ul.to/wyy583e9
★ UP TO 102 SOUNDS including White Noise & Relaxing Music ★
★ PERFECT for Yoga, Working Out & to OVERCOME insomnia! ★
★ RELAX & SLEEP like you haven’t in a LONG time! ★
With the help of zen sounds including water running, birds in a forest, or distant ocean waves, reach a peaceful state of mind to increase your meditation. Perfect to release tension while massaging or during a yoga session.
Additionally, Relax Melodies Meditation is indented to help you sleep. You can now forget about insomnia and start sleeping better. White noise sounds are specifically designed to overcome insomnia by taking your mind into a deep state of relaxation. It makes the best of each of your sleep cycle while sleeping. Ideal when taking a nap or before going to bed. Sleeping has never been easier.
☆ HOW IT WORKS ☆
1. Create your ambience by selecting relaxing sounds and one or more melody that you like.
2. Slip naturally into a meditative state or a deep sleep
3. Wake up rejuvenated
4. Repeat steps over whenever needed!
☆ FEATURES ☆
✓ 36 high quality ambient sounds including 3 binaural beats frequencies for brainwave entrainment.
✓ Option to upgrade to 102 sounds with 3 additional binaural beats
✓ Create your own ambience mix by combining sounds with relaxing music and adjusting their volumes
✓ Includes 4 mixes by default for easy startup
✓ Create, Save, Name, and Replay your mixes as favorites
✓ Timer system to set a duration to your favorite mixes. Ideal when you’re going to sleep!
✓ Beautiful interface with high quality images
✓ Option to upgrade to play your mixes in the background. Relax while using your other apps!
✓ Yoga Ready! Combats Insomnia!
☆ INCLUDE MOST POPULAR WHITE NOISE, MUSIC MELODY & MORE ☆
♬ White Noise ♬ Rain and Wind ♬ Storm Waves ♬ Tropical Forest ♬ Summer Birds ♬ Water ♬ Ocean ♬ Thunder storm ♬ Wild River ♬ Winter Wind ♬ Tropical Rain ♬ and more!
☆ A UNIQUE EXPERIENCE ☆
Simulate relaxing environments that will make you believe that you are actually there! If the sound of a storm and rain helps you relax for example, you can create tons of combination right out of the box! Simply select the storm and rain sound and adjust their volume individually. Set the volume of the storm louder than the rain sound to put yourself right in the middle of the storm. Lower the storm sound volume to create a different effect such as a quiet evening in the country. For a peaceful moment in the middle of the nature, use different water stream sounds such as a calm water river and add bird chips to it. Alternatively, combine the sound of the ocean or water hitting the ocean shore with a relaxing music melody to simulate a day at the beach. Remove the melody sound for a more focused experience on the ocean.
☆ TRY IT NOW ☆
Although it is commonly used by yoga users, Relax Melodies Meditation can be used in any context to help you relax and sleep. Each melody, white noise, and music track included are optimized to help you overcome insomnia and improve your sleeping experience. Furthermore, proper meditation and relaxation can not only impact your body and mind health positively but also improve your productivity. Relaxing, sleeping, working out and Yoga have never been better!
