Popis: Torrent Search Engine je nejlepší nástroj pro vyhledávání a stahování torrentů přímo z vašeho zařízení!
https://play.google.com/store/apps/details?id=com.apps.tsengine
https://www.uploadship.com/09af8067ccda344f
https://dropapk.com/7snr8o6sgfo0
https://douploads.com/m9fu3k6gz2a2
★ Concurrent mode available to search across all providers concurrently
★ Download files directly on your device (you need a torrent client app on your device. If you don’t have it, you will be asked to download one for free)
★ Copy or share torrent and magnet links. Use magnet as favorite, it’s more reliable and doesn’t require .torrent file download
★ Filter torrents by categories
★ Remove torrents without seeders option in settings
★ You can choose the following sort criteria for torrent results:
• speed
• peers
• seeders
• leechers
• oldest
• latest
• size (ascending and descending)
★ Search suggestions based on your search history
★ Forward magnet links and download from your computer using a torrent remote app ( when you tap "download with torrent client” you can choose a torrent remote app if available on your device)
★ Voice Search Integration
You can open the app and show search results using your voice! For example “Search ubuntu on Torrent Search Engine app” and the app will be automatically opened with your results.
