PRO Features Unlocked
Pozadavky: Android 4.3 a vyšší
Popis: Make a slow motion video! You can also make magic fast motion video. This is post-processing editor. You can edit your video and change a speed of it.
design changes: en-US
https://play.google.com/store/apps/details?id=com.mobile.bizo.slowmotion
https://webshare.cz/#/file/2dvy41ri4R/slow-motion-video-fx-fast-slow-mo-editor-v1-2-20-pro-apk
https://uploads4u.net/l6y6vu99whun/SlowMotionFX_v1.2.20_PRO.apk
https://dropapk.com/2wl6rtiusbkt
- record your speech and make it slow - you'll sound really strange;
- make your speech fast - you will sound like a tiny little mouse!
- record some objects falling down like - table spoon, nuts, seeds and... make it slow - it will look funny!
- record you spitting water and slow it down;
- record your pets in slow motion;
- slow down your sport activities. make a slow motion when you ride on your snowboard or during surfing;
- change the movie when you do activities like running. Make the slowmo video from it;
- and of course all other ideas that come to your mind
How to use the slow mo app:
1) choose the video you want to slow down or speed up. u can choose it from gallery, or record the new one. Remember, this is just post processing app, and we can not magically find more fps, then your hardwere camera has. You can slow motion 24 fps, but it will look less naturally, then if your camera record more fps.
2) add the points to the timeline, move them. If you move the point up, you will add the speed to your movie. If you move the point down, you will make the video slower. If you leave the poin in the middle, the speed of the video will not change.
3) play with points, and save video to your gallery!
4) play video in our slow motion player, choose it from gallery.
Our slow motion maker is the only one, whitch alow to create many points with different speed in one movie. The speed in our app is changing smoothly.
Try some examples in this slo mo video editor:
- slow motion with music
- slow motion hair flip
- slowmo baseball swing
- breakdance, cat drinking, car crash and more.
