110,-Kč
Požadavky: Android 4.4 a vyšší
Popis: 174/5000
S vydáním nejnovější verze jsou videa trochu zastaralá: na tomto odkazu najdete krátkou příručku, která ukazuje, jak používat tlačítka v novém formátu.
https://play.google.com/store/apps/details?id=com.inkandpaper&hl=en
https://www.uploadship.com/788701e934a72262
https://uploadrar.com/9q9m7nwzzhto
https://dropapk.to/v6vz45z5vt32
https://uloz.to/file/pjclg6OOexSq/ink-paper-handwrite-pdf-notes-apk
• Write on your Android device like you would on a sheet of paper.
• Six customisable types of pens with the best digital inking features are available.
• Insert in the most natural way typed texts, images, geometrical shapes in your pages.
• Select and move, zoom, rotate, stretch any object using your fingers.
• Control undo and redo actions with the undo/redo bar.
• Overlay objects and manage their opacity using layers.
• Take full advantage of an active stylus by configuring the erase methods.
• Work with close up writing mode on small screen devices.
• Use gestures to select or delete objects while you are writing.
• Set the background of any page by the import of JPEG, PNG and PDF documents.
• Create new notepads from the most common document templates.
• Save and load customised sets of colours, pens, typewriters.
• Organise your notes into library folders. Cut, copy and paste notepads and pages.
• Export and share documents in PDF, JPEG, PNG formats. The PDF format is entirely vector based.
• Backup and restore any section of the library in ZIP format.
