22,-Kč
Popis: Podle našich jednoduchých a ilustrovaných pokynů můžete snadno porozumět zařízení kola, upravit jej a opravit.
https://play.google.com/store/apps/details?id=ru.milviknik.remont_velosipedov&hl=en
https://www.uploadship.com/b8274e90fdba9101
https://uploadrar.com/g59m2qioukqv
https://dropapk.to/mhs2bsbbqp17
The application contains instructions for repairing the bike:
Removing and installing wheels
Camera replacement
Tubeless tire installation
Eight correction
Bulkhead bushings on bulk bearings. Front
Bulkhead bushings on bulk bearings. Back.
Pedal replacement
Rear derailleur setting
Front derailleur setting
Brake setting V-brake
Adjust the height and angle of the saddle
Elimination of "squeak" disk brakes, V-brake brakes
Recommendations for the proper use of switches (shifters). (soon)
Carriage change (soon)
Chain installation (soon)
Bike computer installation (soon)
Mechanical disc brake setting (soon)
In the following updates:
Bulkhead bushings on industrial bearings; front, back.
Gear shift repair
Brake repair
