QR Code & Barcode System Pro
09. 10. 2019 22:38
QR Code & Barcode System Pro v29.0-full
250,-Kč
Popis: Jednoduchý systém komerčních čárových kódů a QR kódů.
https://play.google.com/store/apps/details?id=com.pmobile.barcodeapppro
https://www.uploadship.com/78ebf48e94569c4a
http://ul.to/ejrp755a
https://mixloads.com/enulju5bl562
Fast QR Code and Barcode Reader and Saver
Inventory tracker enables you to keep track of stock numbers of your products.
Calculation module enables you to sum prices of items scanned and reduce stock numbers when you do "sale".
How To use?
* Simply touch "Start" button and preview QR Code by using camera of your device.
* If the scanned code is saved before, the details will be shown.
* You can disable this from "Settings" page.
* You can switch Flash ON/OFF when light is not enough.
* You can read and save to database QR Codes and barcodes.
* By "Inventory Tracker" button you can manage stock infos of records. Select an item to add stock input/output.
* By "Transactions Report" button you can see DAILY, WEEKLY and MONTHLY stock transactions.
* By "Browse Results" button you can search and filter in saved codes. By selection one of them, you can edit or delete it.
* By "Export Results" button you can export results to an XLS (excel) file. The file is saved to "qrcode_reader_exports" directory in your SD Card.
* By "Import Results" button you can import data from an XLS file located in "qrcode_reader_exports" directory into database.
* It is HIGHLY recommended to export results to a file regularly to avoid DATA LOSS.
You can add image to records at Browse->Record Details page.
Touch Edit button, touch Select Image button and touch Save button.
Calculation Mode Usage
1. Scan the barcode. If a record found, the item will be listed and the price will be summed.
2. Touch Scan button to scan and add new items.
3. Touch the item to edit number of copy.
4. Touch the cancel button on the item to remove from list.
11. 01. 2020 21:53
Re: QR Code & Barcode System Pro
QR Code & Barcode System Pro v31.0-full
Přidána možnost vytvoření faktury.Byl přidán přehled příjmů
https://www.uploadship.com/a7b36d5316a094d0
http://ul.to/jdxz2i3h
https://mixloads.com/gcp68dxpwu7y
https://webshare.cz/#/file/6aL1y36Yx5/qr-code-barcode-system-pro-31-0-apk
