Date Calculator Calculate Age Days
09. 11. 2019 12:45
Date Calculator Calculate Age Days v1.1 [Mod][ads-free]
Požadavky: Android 4.4 a vyšší
Popis: Snaží se vypočítat počet dní, týdnů, let a měsíců mezi dvěma danými daty.Zapomínáte na skokové roky při výpočtu?Naše aplikace Kalkulačka dní vám zjednoduší výpočty. a nikdy nebudete bojovat o výpočet dní / data.
https://play.google.com/store/apps/details?id=developer.esperto.dayscalculator
https://upload.ac/heoxaojmw1a3
https://dropapk.to/1uqdb3nf60v4
https://intoupload.net/baueh885a88j
https://webshare.cz/#/file/20t6jo6u7q/date-calculator-calculate-v1-1-apk
1) Simply select the future / Past date and you will find the Answer immediately .
2) if you want to find number of days between two given Dates then that calculation is also made simple with our App . Just select the between dates navigation option at the bottom and put the initial and next Date . the calculation will be done instantly for you .
Features of App
1) Date Calculation made simpler
2) Free to use .
3) Between dates calculation
4) Leap year considered while doing Calculations.
5) Developer Support , if you want to Add some new features or feedback, simply email us we will try to incorporate the new features within the App
Hope you enjoy using the App.
