10. 01. 2020 18:23
Swiftly switch Pro
Swiftly switch Pro v3.2.2 [Paid/Mod]
130,-Kč
Požadavky: Android
5.0 a vyšší
Popis: Cítíte se obtížně používat telefon jednou rukou, chcete zažít skutečné multitasking na mobilu? Pokud je odpověď ano, pak je Swiftly Switch pro vás.
https://play.google.com/store/apps/details?id=org.de_studio.recentappswitcher.pro
https://www.uploadship.com/32629159d60e1053
http://ul.to/axd5008u
https://upload.ac/63mhjcle6w2r
https://webshare.cz/#/file/33a3X54025/swiftly-switch-pro-3-2-2-4allmobile-cz-apk
This handy tool helps you switch between recent apps, favorite apps, access navigation bar, control panel and contacts quickly by one hand from screen's edge of any android device.
FEATURE:
• App switcher: switch between recent, last app, favorite app just by one gesture
• Navigation bar: easily acces home button, back button and notification from edge screen
• Control panel: on/off wifi, bluetooth, rotation, screen brightness, volume,... within one gesture
• Shortcut: support wide range of shortcuts (include tasker’s action)
• Direct call/sms: the fastest way to make phone call/sms to your favorite contact
• Unobtrusive: design as pie control pattern, it only appears when you want to
• FREE, no ads, no internet access, no root require
HOW TO USE
Just swipe from the trigger zone (middle | right of screen as default) to instantly show your recent apps list in a pie control patten, keep your finger on screen, then:
• To switch to recent app: move your finger to the app that you want to switch then lift it up.
• To navigation: the Quick Action are placed on the outer zone of the pie, from here you can access home button, back button, pull down notification panel or you can custom to what actions that you want.
• Access favorite shortcut: they are placed in the Favorite Section. There are two way you can access Favori Dotazy na SZ.
05. 02. 2020 10:48
Swiftly switch Pro v3.2.25 [Paid] [Mod] [SAP]
Požadavky: Android
5.0 a vyšší
- Fix the edge setup load error and some other ways
- Change some display
- Added option to change panel view color
- Added options to change the color and clock size
https://www.uploadship.com/a81fcfe95cfe1d9d
http://ul.to/q2bgqp27
https://up-load.io/nxtvro5aw73r
https://upload.ac/5g5c5niaob8j
https://www.file-up.org/3zudxk61dj3u
https://webshare.cz/#/file/zO8m5785ag/swiftly-switch-pro-v3-2-25-mod-apk
21. 04. 2020 16:47
Swiftly switch Pro v3.2.6 [Paid] [SAP]
Požadavky: Android 5.0 a
vyšší
- Tuto verzi si stáhnete, pokud chcete zálohovat starou zálohu instalace
- Nezapomeňte nastavit šířku v nastavení okraje
- Pokud nefunguje, nezapomeňte povolit oprávnění Zobrazit vyskakovací okno
Mod Info:
Standalone Android Package;
Android App Bundle Repacked:
• Supported CPU architecture: universal;
• Supported Screen DPIs:hdpi [240dpi], xhdpi [320dpi], xxhdpi [480dpi], xxxhdpi [640dpi];
• Languages: Multi Languages.
https://www.uploadship.com/b0320fbe79f7bb09
https://userupload.net/tikti4pdfy7g
https://up-load.io/jb53w0lp6p1i
http://ul.to/z9203oha
https://mega4up.com/t2w50symhnkh
