11. 09. 2019 13:17
The Quest Celtic Queen
The Quest - Celtic Queen v8.0 (Paid)
70,-Kč
Požadavky: Android
4.4 a vyšší
Popis: The Quest Celtic Queen je expanze do The Quest, krásně ručně tažené hry na hraní rolí s otevřeným světem s hnutím založeným na staré škole a tahem založeným na tahu.
https://play.google.com/store/apps/details?id=hu.redshift.thequestexp7
http://breakingnews2018.info/rkhvhmq19mbt
https://dailyuploads.net/n19w3zangxq7
https://dailyuploads.net/jogsu2usumb0
http://breakingnews2018.info/i1waokqlgcpq
After enabling the expansion, you can explore new areas and adventures. However, if you don't have The Quest, you can also play the expansion as a standalone game.
Habren is Queen now, thanks to you. However, King Locrinus' brother Kamber has challenged her right to the throne. He's taken Madden's two sons under his control and assembled an army to fight Habren.
Merlin holds the key to the future and would protect her but he's besieged by an opposing faction of wizards. He calls once more on your skill and daring, Heroic One. It's your mission to make order out of chaos and save the Queen.
To access the new areas (not applicable if you are playing the expansion standalone), go to Mithria harbor and talk to captain Hanty, then select "Celtic Queen" as your travel destination. It's recommended you reach at least level 45 before taking on the challenges posed by this expansion. Dotazy na SZ.
03. 01. 2020 20:41
The Quest Celtic Queen v8.0.3 (Paid)
70,-Kč
Požadavky: Android
4.4 a vyšší
Vylepšená kompatibilita pro Android 10.
https://www.uploadship.com/d0b5144128c1ee5f
http://ul.to/mk4u8839
https://mixloads.com/fllmk7ap867x
Stahuj zde: hu.redshift.thequestexp7 je složka,kam nakopírujeme obb
https://www.uploadship.com/18839ca18fb2d3f9
http://ul.to/ku6gkvep
https://mixloads.com/wohx86s9zlg2
