Požadavky: Android 4.0+
Magnetic HD Theme for Apex Launcher and Nova Launcher – Dark Blue Colored Icons that look great on phones. With 3 HD Wallpapers and tons of custom icons you can totally customize your phone!
This theme is compatible with both Apex and Nova Launcher.
Open App after installation and apply Apex Theme if you are using Apex Launcher or Apply Nova Theme if you are using Nova Launcher.
You can also Apply Wallpapers from the app.
This theme works with both Apex Launcher and Nova launcher.
The weather widget on screen belongs to Palmury Weather.Search “ Palmury Weather “ on Play Store to install.
https://play.google.com/store/apps/details?id=com.photox.magnetichd
http://www15.zippyshare.com/v/67266622/file.html
http://www.embedupload.com/?d=9AYBI3UFIT
http://uploadmirrors.com/download/BHJUTROU/MaHDANT_v1.0.apk
