55,-Kč
Popis: Pro použití Ikony je zapotřebí CUSTOM LAUNCHER. PŘED INSTALACÍ PŘEČTĚTE JEDNOU (NOVA, APEX, ACTION, ETC).
https://play.google.com/store/apps/details?id=com.natewren.moonshinepro
http://breakingnews2018.info/jq3d130vj275
https://uploadev.com/j6t16v4or6mr
https://upload4earn.org/laeh90w5wmvx
https://douploads.com/08oebraky43f
500+ Additional Icons
100+ Material Design Inpspired HD Wallpapers
Material Design Inspired Widgets
WIDGETS
System widgets as well as editable KWGT widgets are included.
• 2 Battery widgets
• Fully Editable Digital clock widgets
• Analog clock widget
• Weather Widget
It is officially time for a new look. Introducing Moonshine.
Inspired by leaks and rumors, we decided to make a full pack following these new guidelines
With the previous leaks of an apparent redesign of the core Android apps, we decided to explore more into the new guidelines, and experiment with them! Some have long shadows, most are flat, and almost all have a pop of color! We are taking Google's guidelines, and applying our own creative touch to them! This icon pack doesn't aim for "consistency"; instead, it aims for a "free form" type of look. Not every icon is supposed to look the same or mimic each other.
FEATURES:
★ Material Design Dashboard App!
★ Muzei Wallpaper Support!
★ 1,600+ vector designed icons
★ 100+ homemade wallpapers!
★ Supports Nova, Apex, ADW, Smart, Unicon, Action Launcher, Aviate, Go Launcher, Next, Holo launcher, Solo Launcher, KK Launcher, Atom Launcher, Evie Launcher, and Inspire Launcher!
★ Icon Picker that shows the latest added icons!
HOW TO APPLY:
1. Download a custom launcher from above (Nova, Apex, ADW, Smart, Action, Unicon, Go, etc)
2. Open the Moonshine application and navigate to the "Apply" tab.
3. Select your dedicated launcher and you are set to go!
4. To access the wallpapers, simply go into the app, select the "Wallpapers" tab, and pick from over a dozen homemade walls!
