5 příspěvků •Stránka 1 z 1
FLUOXYGEN ICON PACK
23. 11. 2019 22:36
FLUOXYGEN ICON PACK
FLUOXYGEN ICON PACK v4.8 [Patched]
60,-Kč
Popis: * 6135 ikon s rozlišením 2K SuperHD + (350 x 350) pixelů!
* 6100+ Podporované aplikace!
https://play.google.com/store/apps/details?id=com.cris87.fluoxygen
https://dropapk.to/wukofi7o28gz
https://upload.ac/ttbaotxls308
https://www.uploadship.com/076e36ca6b56551b
* 55 HD wallpapers with a resolution of 2K (1440x2560) pixels!
* Each icon is designed with extreme care!
Triple Icons Render Process!
* A new system of saturation icons!
* Detailed cleaning and sharpness of icons!
* Dynamic Calendar for the App Stock and Google Calendar!
* Query icons Missing directly through the application (3 for free for each version)!
* The update period is guaranteed!
USE OF INFO:
• This icon pack requires a custom launch pad. Pixel Launcher, Google Now Launcher and any other launch program installed on the device do NOT support Icon Pack (except Asus ZenUI, LG Home, Xperia Home). You can not apply a theme to launchers that do not provide the ability to change icons. So first check your launcher or download a compatible launcher !!!
• In the new Android 7.0 Nougat operating system, LG Home has removed support for external package icons and does not support standard icon packs;
• To fully control the size of the icons, you need to go to the LAUNCHER / APPEAR settings and turn off the "NORMALIZE ICONS" function ... The action required for NOVA LAUNCHER (and all other launchers that provide this function), because the icons are already normalized and not require this option; If you do not, you can find smaller icons!
COMPATIBILITY:
Most of the main launchers on the PlayStore are compatible,
ABC, Action, ADW, Apex, Atom, Aviate, GO, Holo, HoloHD, iTop, KK, Lucid, M, Mini, MN, New, Nougat, Nova, S, Smart, Solo, V, ZenUI, Zero.
It can still be used with many other launchers that support icon packs, but are not listed in the application itself, such as Arrow, ASAP, Evie, Cobo, Line, Mesh, N, Peek and Z Launcher, with Xperia Home and with CyanogenMod Theme Engine, DIRECTLY APPLICABLE TO THE SETTINGS SETUP MENU USED THROUGH THEME / DIMENSIONS OF ICONS;
Not guaranteed compatibility with LG HOME Stock Launcher (should work before android 6.0, but I do not have the opportunity to personally check), can not apply for Samsung, Huawei, Nubia, Meizu, ...
Icon Pack was tested personally without any problems:
NOVA LAUNCHER;
APEX LAUNCHER;
EVIE LAUNCHER;
THE TASK OF ACTION 3;
HOLA LAUNCHER;
YANDEX LAUNCHER;
ZEN UI LAUNCHER;
29. 11. 2019 17:43
Re: FLUOXYGEN ICON PACK
FLUOXYGEN ICON PACK v4.9 [Patched]
- 15 nových ikon;
- 6145 ikon celkem;
- 6100+ podporovaných aplikací;
- 55 tapet celkem s rozlišením 2K;
- PŘIDANÁ PODPORA PRO POCO LaUNCHER!
- PLNÁ KOMPATIBILITA S JEDINÝM PLUS Launcherem!
- Aktualizované a optimalizované kódy XML a Java;
- Přidána tlačítka pro darování a požadovat prémiové ikony;
- Přidány odkazy na stránku na Facebooku a Telegram Group v sekci ABOUT;
https://up-load.io/z8ymxdtzxc8w
https://uploadrar.com/4g720emdytnc
https://upload.ac/cmtoq9d7crv4
11. 03. 2020 13:53
FluOxygen Icon Pack v5.3 [Patched]
- 15 nových ikon;
- celkem 6185 ikon;
https://uloz.to/file/MelvUCLxQcsF/fluoxygen-5-3-apk
https://ulozto.sk/file/7Jq3CrlO9pzV/fluoxygen-5-3-apk
https://ulozto.net/file/40LYgeoaocHF/fluoxygen-5-3-apk
https://webshare.cz/#/file/3b31857Jk4/fluoxygen-5-3-apk
Naposledy upravil(a) milann70 dne 13. 05. 2020 05:21, celkem upraveno 1 x.
28. 03. 2020 12:26
FluOxygen Icon Pack v5.4 [Patched]
- 15 nových ikon;
- celkem 6190 ikon;
- Podporováno 6100+ aplikací;
- aktualizován a optimalizován kód XML a Java;
- Přidány tlačítka darů a ikony prémiových požadavků;
- Přidána stránka Facebook a odkazy Telegram Group v sekci About;
https://www.uploadship.com/34433a38b181ba47
https://uploadrar.com/luuqappx8cgm
https://dropapk.to/k20j3ytalvdf
https://upload.ac/vvwzt548rprr
https://webshare.cz/#/file/75f78p3k2Y/fluoxygen-v5-4-apk
13. 05. 2020 05:39
FluOxygen Icon Pack v5.6 [Patched]
- 15 nových ikon;
- celkem 6245 ikon;
- Podporováno 6200+ aplikací;
- 80 tapet celkem s rozlišením 2K;
https://www.uploadship.com/7e95360ea70ee4c7
https://dropapk.to/sz3vp0c3nxwj
https://mixloads.com/dgb7h08uvi8z
https://uloz.to/file/Q0JMisk248jw/fluoxygen-v5-6-p-apk
https://webshare.cz/#/file/WmM14Z6C3Y/fluoxygen-v5-6-p-apk
