08. 12. 2019 09:50
Flux White Substratum Theme
Flux White Substratum Theme v3.9.5 [Patched] [updated]
Požadavky: Android
7.0 a vyšší
+ Substratum Theme Engine + Root
Popis: Téma Flux White pro Substratum je navrženo s dokonalou přesností a materiálem pixelů, aby poskytlo vašemu telefonu zcela nový moderní vzhled a dojem! Díky vysoce kvalitní vektorové grafice a plným funkcím si užijete používání telefonu!
https://play.google.com/store/apps/details?id=flux.white.substratum
https://dropapk.to/3zue9q8zgkuc
https://upload.ac/w7n5k1l58mwh
https://uploadrar.com/mv37onavapub
https://www.uploadship.com/7b5ac27bc6fe6097
https://netdisk.sk/file/_5-74N6NI0H6eyMqMeKpLg
https://uloz.to/file/f9HbrBUCZQCf/flux-v5-2-9-p-apk
Works with android 7.0/7.1.2 with OMS support and all DPI sizes!
It also works on stock/legacy roms as well but some icons may not be themed.
(OxygenOS and Samsung are not supported).
FAQ/HELP
• Battery icon cannot be themed in qs panel. You can move it as your 7th icon so it does not show in the first row. Some roms do not have the latest patches from substratum
and the rom devs need to include them for the battery to show correctly.
• If you are using LineageOS keep in mind it does not support OMS so Flux will not work properly and you may encounter bugs/issues not possible to fix.
• Some of your settings icons are just blue circles or invisible?
- This happens because the rom you are using does not include the latest patches for the icons to be themed. You can contact your rom dev to include the latest substratum patches.
• Having issues with notifications not displaying correctly?
Restart and disable the dynamic notifications color in settings, if you have this option.
• Restart your phone after every update is highly suggested.
• Beta software are not supported even though my theme may work with them.
• Your phone stuck in boot loop?
- Go to your recovery and flash the rescue zips located in Substratum folder. Dotazy na SZ.
20. 03. 2020 03:47
Flux White Substratum Theme v4.0.8 [Patched]
Požadavky: Android 7.0 a
vyšší + Substratum Theme Engine + Root
• Vylepšení v15 bez root
• Vylepšený obchod
• Různé opravy a vylepšení
https://dropapk.to/0oc1uhbwqrcl
https://www.uploadship.com/0448a63cab1daaf7
https://uloz.to/file/d8isidoTjXRL/flux-white-v4-0-8-apk
https://ulozto.sk/file/rrXGSInFotla/flux-white-v4-0-8-apk
https://webshare.cz/#/file/5xx5rq62i2/flux-white-v4-0-8-apk
20. 03. 2020 04:07
Flux White Substratum Theme v4.1.3 [Patched]
• Přidán vlastní výběr barvy (pouze substrátum lite)
• Tématický substrát lite
• Vylepšený systém Android 10
https://www.uploadship.com/866a07f013bc4747
https://dropapk.to/4mkgv16dnul3
https://uloz.to/file/wtJb9O0Puink/flux-white-v4-1-3-apk
https://ulozto.sk/file/od7V9DZSROoG/flux-white-v4-1-3-apk
https://webshare.cz/#/file/6Yu58W57H3/flux-white-v4-1-3-apk
25. 03. 2020 06:13
Flux White Substratum Theme v4.1.4 [Patched]
• Improved custom color picker
• Improved instagram
• Improved whatsapp
• Misc ui fixes and improvements
https://www.uploadship.com/3b2d2c326b8f1648
https://uploadrar.com/d3p5kkz805aa
https://dropapk.to/li99xh6hv05x
https://upload.ac/x2o69gpzzey9
https://uloz.to/file/ytP4fyjqydn0/flux-white-v4-1-4-4allmobile-cz-apk
https://ulozto.sk/file/XYTcaFcrxR9G/flux-white-v4-1-4-4allmobile-cz-apk
https://ulozto.net/file/mPs38NgTBXtK/flux-white-v4-1-4-4allmobile-cz-apk
https://webshare.cz/#/file/4Zz5337b35/flux-white-v4-1-4-4allmobile-cz-apk
12. 04. 2020 10:58
Flux White Substratum Theme v4.1.7 [Patched]
• Vylepšený Google dialer
• Vylepšeno Whatsapp
• Vylepšené ikony nastavení samsungu 10
https://www.uploadship.com/50b12a13d94d77ba
https://uploadrar.com/wot2vf1bj1nx
https://dropapk.to/zxkj20t3y01u
https://upload.ac/i7luus9b1wol
https://webshare.cz/#/file/jUoAmpDqsk/flux-v5-5-7-p-apk
07. 06. 2020 13:14
Flux White Substratum Theme v4.2.5 [Patched]
Požadavky: Android: 7.0 a
• Themed samsung keyboard v5
• Fixed google clock 6.3
• Improved android 10 framework
• Improved gmail
https://uploadrar.com/op2zlxjfcsso
https://dropgalaxy.in/g7996d5gmao6
https://dropapk.to/zg43mb1fdd1q
https://mixloads.com/hdpawp8sz3ig
https://www.uploadship.com/3137e84749b741fd
https://uloz.to/file/unMVXDRmHLtQ/flux-white-v4-2-5-4allmobile-eu-apk
14. 06. 2020 10:07
Flux White Substratum Theme v4.2.6 [Patched]
Požadavky: Android: 4.0 a
vyšší +
• Vylepšené úkoly Google
• Vylepšený Android 10 aosp hodiny
https://dropgalaxy.in/dplnq3uk7ajm
https://dropapk.to/gyqx2gpbcuvy
https://mixloads.com/12wlpvl2ypc6
https://www.uploadship.com/3d9edc4010337708
https://uloz.to/file/9juFy8h3xcW9/flux-white-v4-2-6-4allmobile-eu-apk
20. 06. 2020 17:53
Flux White Substratum Theme v4.2.7 [Patched]
• Vylepšený systém samsung 10
https://uploadrar.com/8vcq491btac9
https://dropgalaxy.in/g8v517lffj28
https://dropapk.to/2hlc0avvgb4j
https://mixloads.com/g1uvcudsfohl
https://uloz.to/file/RdYCTtFg6bmr/flux-white-v4-2-7-4allmobile-eu-apk
22. 07. 2020 20:42
Flux White Substratum Theme v4.3.1 [Patched]
• Playstore v21 cant be themed
(overlay temporarily removed)
• Improved android 10 aosp dialer
• Improved android 10 aosp contacts
https://uploadrar.com/wlhzdq0z3xot
https://dropapk.to/ad8fwyb9qyja
https://dropgalaxy.in/32zmmat4dv3s
https://mixloads.com/iw3uqimhmpjo
