Verzia so sence Storage 68,50 in use,18 free
program 108,in use 82,free 26 MB
10 Mb sa da ziskat vypnutim dialera
titanium light ma vacsie hodnoty,lebo je bez manily...
na druhej strane toto je hard version,ktora ma vela pg.buildnutyx v ROM,staci si vybrat-nie je tam len jedna
"Standard" includes the new TF3D2 (Rhodium Manila) along with the standard Windows Mobile 6.5 today plugin (Titanium*) and the Tachi dialer
"Titanium" only includes the Titanium today plugin. No Manila in this version. This also includes the regular HTC dialer
Therefore your available RAM will be greatly reduced.
This ROM was designed for high RAM devices such as the TP. I was asked to make a Diamond version and I did, but unfortunately the Diamond's limited RAM quickly runs out with this ROM.
To alleviate that, try not to run Manila and give Titanium a shot. You could also disable the fancy dialer to get 10 more megs of RAM back. HTCaddicts CleanRAM is highly recommended to keep RAM usage under 90%., but don't go crazy with it. Try the lower "levels" first.
Toto pisal pan Kuchar
http://forum.xda-developers.com/showthread.php?t=517300
