Cesta v registrech
Slavek69
HTC Touch Pro
16. 11. 2007 14:00
16. 10. 2008 23:15
Cesta v registrech
V jednom z uvedenych navodu zde ve foru je uvedeno toto:
If you want QMail to invoke automatically every time you tap a 'mailto:' link in Pocket IE, you should change some things in registry (as you may guess!)
\HKCR\mailto\Shell\Open\Command - rename Default to Default_old. Create new string value Default, then set it to "\full path\to the program\QMail\q3u.exe" -s "%1" (do not forget quotation marks!)
Use the next tweak if you do not want Inbox to start in the background every time you put your device in the cradle for syncing.
\HKLM\SOFTWARE\Microsoft\Shell\Event\Dock\Inbox - rename command to command_old.
Tak zkus treba tento postup, mohlo by to fungovat.
Prosím o radu, jak přesně bude vypadat cesta, když mám Qmail v paměti zařízení ve složce Program Files v podsložce Qmail a soubor se jmenuje q3u.exe. Předem děkuji za radu.
_darebak_
Mobil Extra User
SE Xperia Arc S
21. 03. 2008 13:34
17. 10. 2008 07:13
Re: Cesta v registrech
skus
"\Program Files\QMail\q3u.exe" -s "%1"
Sony Ericsson Xperia Arc S
Unlocked Bootloader » DooMKernel v15 » Arconium 3.0a - Experimental Tweaks [4.0.2.A.0.58]
Sony Ericsson Xperia X10mini ● Gingerbread 2.3.7_MiniCM7-2.1.4
Asus P535_128MB RAM ● WM6.1_PDAVIET_Build 21028.1.6.0
Mobil Extra User
