F-Sim Space Shuttle
03. 10. 2012 07:06
F-Sim Space Shuttle
F-Sim Space Shuttle v2.0.111
Požadavky: Android 2.3+
SDcreen:
With F-Sim Space Shuttle, a number one flight simulator for iOS finally arrives on Android. It simulates the space shuttle’s approach and landing in unprecedented detail and accuracy. Take command of the Orbiter during the final minutes of descent, and touchdown safely at the John F. Kennedy Space Center or Edwards Air Force Base.
After the landing, you can watch a replay of your flight from different perspectives, like a chase plane or from the tower. A sophisticated landing analysis also is available, and only the best pilots are awarded a “perfect landing” score.
The Orbiter’s approach is seven times steeper and twice as fast compared to a commercial airliner’s approach. Also, because during descent it is an unpowered glider, you only have one chance to get it right.
The included manual and tutorials will familiarize you with the head up display (HUD) and explain the different approach and landing phases. After some practice and your first successful touchdown, you can try crosswind or night landings.
Striking realism
Flight dynamics, the guidance, navigation, and control (GNC) systems, and the HUD are simulated accurately and in great detail.
Follow the guidance symbol in the HUD to stay on the heading alignment cone (HAC) and align the orbiter with the runway centerline, and then follow the flare reference symbol to perform the preflare maneuver. Don’t forget to keep an eye on the visual landing aids like the precision approach path indicators (PAPI) and the ball/bar light system to stay on the outer and inner glideslopes, respectively.
Let the autopilot control rudder, speed brake, gear, and chute, or control them yourself. If you dare, simulate system failures like a stuck speed brake or HUD/guidance malfunctions.
A wide range of options
Take your place in the commander’s seat in the stunning virtual cockpit, or view your flight from different external camera perspectives. Choose between accelerometer (tilt) controls or (virtual) analog sticks to steer the Orbiter. Land on both shuttle landing facilities, and fly either final or full approaches by selecting one of the four possible HACs. Configure day or night landings, clear or overcast skies, visibility, wind, and many other parameters.
What's in this version :
Updated : Sep 30, 2012
A lot of improvements and fixes for all known problems, including:• Improved texture quality on devices with ETC texture compression (e.g. Galaxy S2/3).
Added support for devices with 16MB RAM.
On some devices the HUD was black, this has been fixed now.
F-Sim runs flawlessly on the Galaxy S2 now.
mute audio in silent & vibrate mode
https://play.google.com/store/apps/details?id=net.ledinsky.fsim
http://www16.zippyshare.com/v/16082900/file.html
http://uloz.to/xtVFjZf/fsss-v2-0-111-apk
16. 02. 2013 22:57
Re: F-Sim Space Shuttle
F-Sim Space Shuttle v2.2.063
A lot of improvements, including:
• Chute
• Wingtip vortices
• New camera perspectives
• Switch between camara perspectives in replay
• Display score at end of flight
We’ve tested this version extensively on a large number of devices. If you still run into problems, please let us know and we’ll do our best to fix them.
F-Sim Space Shuttle v2.2.063 [ICS]
http://uloz.to/x24ZoRv/f-sim-space-shuttle-v2-2-063-ics-apk
https://mega.co.nz/#!oNYHib7D!TGn3chy1Wkkp3fdIWlZWuUtaD-M0JgDmF3rpGiipGZI
http://www64.zippyshare.com/v/24513087/file.html
F-Sim Space Shuttle v2.2.061 [JB]
http://uloz.to/xuNCQ7z/f-sim-space-shuttle-v2-2-061-jb-apk
https://mega.co.nz/#!RY5ykDyb!MlrnZH1DEpMbPP_wzCcU72dZ_GAwccbSTmXMoKIruBc
http://www20.zippyshare.com/v/87565617/file.html
11. 04. 2013 22:35
F-Sim Space Shuttle v2.2.074 [ICS]
Pozadavky: Android 4.0+
• Chute
• Wingtip vortices
http://uloz.to/xbVwu8cE/f-sim-space-shuttle-v2-2-074-ics-apk
http://www1.zippyshare.com/v/60647065/file.html
25. 12. 2013 22:06
F-SIM Space shuttle v2.4.093
- 3D sound and improved sound effects
- highscores and achievements
- save and share replays
- automatic backup of settings and stats data
- video recording (beta)
http://uloz.to/x6KRfL2G/f-sim-space-shuttle-v2-4-093-4allmobile-eu-apk
http://www78.zippyshare.com/v/59411197/file.html
panborec
09. 10. 2008 20:12
30. 12. 2013 22:34
nainstaluju to ale nejde to spustit.xiaomi red rice
28. 01. 2014 23:13
F-Sim Space Shuttle v2.4.253
• 3D sound and improved sound effects
• highscores and achievements
• save and share replays
• automatic backup of settings and stats data
• video recording (beta)
[Android 4.1+]
http://uloz.to/xdyzvGU8/f-sim-space-shuttle-v2-4-253-4-1-apk
http://www65.zippyshare.com/v/26903568/file.html
[Android 4.0]
http://uloz.to/xrgkECwJ/f-sim-space-shuttle-v2-4-253-4-0-apk
http://www65.zippyshare.com/v/79411999/file.html
