Application Folder Pro
13. 11. 2012 14:44
Application Folder Pro v2.9.8
(30,- Kc)
Popis: Make your own pretty folders!
This application provides folders in your home with pretty icons.
Unlike default android folder, this is very easy and pretty and you can change the folder name and icon.
For the convenience, application folder shows the number of application as a badge.
Just take a look at screenshots!
Recent changes:
- Minor bugs fixed
- Widget resizing in Tab
https://play.google.com/store/apps/details?id=personal.jhjeong.app.appfolder
http://uloz.to/xeZDkad/application-folder-pro-v2-9-8-apk
http://www.directmirror.com/files/WNSFIOEK
http://www.embedupload.com/?d=3DE2ZGK5MY
27. 12. 2012 07:35
Re: Application Folder Pro
Application Folder Pro v3.0.0
Požadavky: Android v2.1+
Updated: Dec. 27, 2012
New widget and new folder
http://www19.zippyshare.com/v/63971100/file.html
http://www.embedupload.com/?d=3CROBPGHHY
http://uploadmirrors.com/download/1OKIP8XM/Application_Folder_Pro_v3.0.0.apk
