Popis: Jobs Chronometer is way to manage your self business when every second is important, the best way to have all control of your time and how much money you make every minute, I will calculate it for you, you just start the the chronometer and stop when you end it. This chronometer will alarm you when the time is over, and will bring give you the invoice option.
- nova aplikace
https://play.google.com/store/apps/details?id=com.dsalab.jobchronometerKód: Vybrat vše
http://www.tusfiles.net/yqvyatye1iw5
http://www.kingfiles.net/3vji3pdib1mx/com.dsalab.jobchronometer.ver.1.0.build.1.zip
http://unlimitzone.com/imfg6cq2uecz/com.dsalab.jobchronometer.ver.1.0.build.1.zip.html
http://rapidgator.net/file/4f07276da54da5245d8ff74bde8f8ab5/com.dsalab.jobchronometer.ver.1.0.build.1.zip.html
You even can pause the time, for example for lunch. Even you will be able to see the story of your time and how much cash you are making. It's perfect when you work at home adding and emergency button that it will call a emergency if you need some help when you are still working, and I will text via whatsapp to someone that you want for help. You are at home, you are working, things happens, you never knows.
//TODO
1-Integrate with bluetooth printers, to print your invoice and business history.
2- Customer List.
3- Integrate with other text message apps.
4- Partner List.
5- Search on history by criteria.
6- Mail business history.
