22. 12. 2014 14:50
Heavens-Above Pro
Heavens-Above Pro v1.2
(110,- Kc)
Popis: When can I see the ISS? What's that light in the sky? The official Heavens-Above app provides you with precise pass predictions for the ISS, visible satellites, Iridium flares and radio satellites.
Zooming into the sky chart reveals the names of constellations and stars (Android 3 and newer)
Info pages get cached for offline use
Bug fixes
Vice info:Kód: Vybrat vše
https://play.google.com/store/apps/details?id=com.heavens_above.viewer_pro
Stahuj zde:Kód: Vybrat vše
http://www.tusfiles.net/s52ks1ljkrf9
http://uloz.to/xwU4KMSq/heavens-above-pro-v1-2-apk
https://webshare.cz/file/5Us7mr2Fe5/heavens-above-pro-v1-2-apk
http://www.embedupload.com/?d=0DYOFMC3UF
When can I see the ISS? What's that light in the sky? The official Heavens-Above app provides you with precise pass predictions for the ISS, visible satellites, Iridium flares and radio satellites. Main features include:
No advertisements
This version is free of advertisements. You can try the free version before buying this one.
Live sky chart
See what's in the sky above you right now or at a given moment.
Pass predictions
Get precise predictions for passes of the ISS and most visible satellites.
Iridium flares
See when Iridium satellites mirror the sunlight directly towards you, resulting in bright flares.
Radio satellites
Get passes for amateur radio satellites, complete with uplink and downlink information.
All calculations performed locally
Predictions are generated right on your phone so you only need a data connection every few days.
Orbit and ground track
See details about the orbit of any selected satellite rendered and with all relevant data.
Satellite details
Get detailed information about any satellite, as provided by our Heavens-Above website.
Timeline
Get a visual overview over passes and animate the position of satellites on the sky chart and on the ground track.
Night mode
An optional red on black color scheme to preserve your night vision.
Tracker
Easily find or identify any object in the sky by orienting your device towards it.
Calendar Integration
Quickly add interesting passes to your calendar so you won't miss them.
03. 01. 2016 22:37
Heavens-Above Pro v1.4
Notifications for upcoming passes and flares
Daytime flare predictions
Improved layout for tablets in portrait mode
Improved calendar entries
Multiple satellite selection
Share feature
Quick filters
https://userscloud.com/kixz86f2wods
https://dailyuploads.net/90170s03jrlq
https://tusfiles.net/ytapuwnxg0ia
10. 06. 2018 01:30
Heavens-Above Pro v1.52
2.3 a vyšší
Improved night theme
Improved sky chart with critical elevation
Setting for an enlarged sky chart
Timeline jumps to the time of the predicted pass
Timeline adjusts for the planets view
http://suprafiles.org/2z0v9eundnsx
https://douploads.com/v2ujo31bzgey
https://uloz.to/!Y85DQeKBaOfX/heavens-above-pro-1-52-apk
Naposledy upravil(a)
milann70 dne 16. 06. 2020 03:53, celkem upraveno 1 x.
16. 06. 2020 03:52
Heavens Above Pro v1.63 (Patched)
Požadavky: Android: 2.3 a
vyšší
se na GP neuvádí
https://dropapk.to/5l203vktc4vm
https://uloz.to/file/ptMTioHJKNH7/heavens-above-pro-4allmobile-eu-apk
19. 06. 2020 20:02
Heavens Above Pro v1.65
vyšší
Brazilský překlad.
https://www.uploadship.com/75cbebae94c40be8
http://ul.to/72ol8mxb
https://uloz.to/file/KqZCHwKXm0XH/heavens-above-pro-4allmobile-eu-apk
