Requirements : ↑4.0.3
Overview :INFORMATION-
* Beautiful Theme Inspired by Xiaomi MIUI 8 !!!
* The First Icon Pack to the World in HD !!!
* Amazing resolution icons (300x300) pixel !!!
* Each icon is Designed with Extreme care of details !!!
* Smoothing corners faithfully reproduced as the original !!!
* Outlines Internal and External Effect Charcoal !!!
* Triple Rendering Process of icons !!!
* Auto Masking for app icons missing !!!
* Over 500 Supported Applications with First Release !!!
* 50 HD backgrounds with 2K resolution (1440x2560) pixel !!!
* Dynamic Calendar App for Stock & Google Calendar !!!
* Request Icons Missing directly through the app !!!
* Update Periodicals Guaranteed !!!
* Assistance, Support & Info on the new Future Projects and development on my website: http://www.cris87.altervista.org
ABOUT USE:
• This icon pack needs a custom launcher to be applied. Pixel Launcher, Google Now Launcher and any other launcher that is preinstalled on the device do NOT support the Icon Pack (Except for ZenUI Asus, LG Home, Home Xperia). There is no possibility to apply the theme of launcher that do not provide the ability to change the icons. For this please check before your launcher or provide for downloading a launcher compatible !!!
• With the new operating system Android 7.0 Nougat, LG has removed the Home icon support external packages and does not support standard icon pack;
• To request missing icons, just go on my website under Request Icons and send me a message with the name of the icons you want; After making the request, you have to wait as long as necessary for the organization and implementation of the same icons and related xml..pertanto code will pass the days between one update and the other;
COMPATIBILITY:
They are compatible most major launcher on the PlayStore,
ABC, Action, ADW, Apex, Atom, Aviate, GO, Holo, HoloHD, iTop, KK, LG Home, Lucid, M, Mini, MN, New, Next , Nougat, Nova, S, Smart, Solo, V, ZenUI, Zero.
However, it can be used with many other launcher that support icon packs but are not specified within the application itself, such as Arrow, ASAP, Evie, Cobo, Line, Mesh, N, Peek and Z Launcher, with Xperia Home and the CyanogenMod Theme Engine, Apply directly into MENU SETTINGS USED bY SECTION LAUNCHER THEMES / ICONS;
The Icon Pack has been tested personally smoothly with:
NOVA LAUNCHER;
APEX LAUNCHER;
EVIE LAUNCHER;
ACTION LAUNCHER 3;
HOLA LAUNCHER;
YANDEX LAUNCHER;
ZEN UI LAUNCHER;
What's New :
v7.2
- Added Tab With The New Icons Inserted For Each Update;
- 30 New Icons;
- 2995 Total Icons;
- 2900+ App Supported;
- 105 Total Wallpaper with Resolution 2K;
- Updated and Optimized Xml and Java Codes;
- Added Donation Buttons and Request Premium Icons;
- Added Facebook page links and Telegram Group in the ABOUT section;
Google Play :
https://play.google.com/store/apps/details?id=com.cris87.miuicarbonKód: Vybrat vše
https://uloz.to/!FuzRrgP8JJfV/miui-carbon-icon-pack-hd-v7-2-apk
https://upload4earn.org/cugid7vb1p39
