120,-Kč
Popis: HttpCanary je výkonný HTTP / HTTPS / HTTP2 pakety zachytávání a analyzátor aplikace určené pro platformu Android. Můžete si myslet, že je to mobilní Fiddler nebo Charles.
https://play.google.com/store/apps/details?id=com.guoshi.httpcanary.premiumKód: Vybrat vše
https://dropapk.com/5tzevmc7xc7h
https://douploads.com/jfv38axo9yor
https://userscloud.com/hfi1ykhjworj1. NO ADS.
2. Http request and response injections.
3. Support repeat, compose and copy cURL.
4. All powerful plugins are available.
5. More powerful functions in future.
What's New:
- Support video preview.
- Add time options for history.
- Optimize app search.
- Minor bug fixes and improvements.
Most Important:No root required! No root required! No root required!
HttpCanary supports packets capture and injection. With this app, you can test your mobile Reset APIs very very easy. Besides, HttpCanary provides multiple view browsers, such as raw viewer, hex viewer, preview viewer and so on.
* Support Protocols
HTTP1.0, HTTP1.1, HTTP2.0, WebSocket and TLS/SSL.
* Support Devices
Any android arm or x86 devices include emulators.
* Injection Feature
HttpCanary provides two different modes for the injection: static mode and dynamic mode. You can inject query parameters, headers, bodies and status line. You can create injectors with different requirements, and the static mode supports multi injectors at the same time.
* View Browsers
Raw viewer, shows the raw packets data.
Text viewer, shows the body data as a text.
Hex viewer, shows the body data as a hex string.
Json viewer, shows the formatted json data, supports node expand and collapse.
Image viewer, support show BPM, PNG, GIF, JPG, WEBP formats.
Audio viewer, support play AAC, WAC, MP3, OGG, MPEG formats.
* Content Overview
HttpCanary displays multi-dimensional session overview. Includes URL, http protocol, http method, response code, server host, server ip and port, content type, keep-alive, timing, data size and so on.
* Packets Filter
HttpCanary multi-dimensional filters, you can filter the packets by app, host, protocol, method, ip, port and keywords.
* Blocking settings
You can choose to block the requests and responses, it is easy to debug your REST APIs.
* Plugins
HttpCanary supports many plugins include experimental plugins and extension plugins. Now there are some experimental plugins integrated in the app such as HostBlock, Mime-TypeBlock, Downloaders and OverviewStatistics. In the future, we will publish the extension plugin-sdk for the developers and supports the extension plugins.
At the end, HttpCanary core codes are opened in Github, we hope HttpCanary can help more people.
