27,-Kč
Požadavky: Android 4.0.3 a vyšší + SAI (Split APKs Installer)
Popis: iOS Lines - Neon je ikona pack / Icon Changer pro nova, evie a další.
https://play.google.com/store/apps/details?id=com.panotogomo.squarelinesKód: Vybrat vše
https://dropapk.to/kpy7kqzql8uk
https://upload.ac/0vxpx30l1lra
https://www.uploadship.com/92a99c2744452a06- 5000+ icons and counting
- Iconback for your unthemed icons
- 16+ HD Wallpapers
- Alternate icons
- Icon Request
- HD Icon resolution 192x192px
How to apply iOS Lines - Neon Icon Pack?
This iOS Lines - Neon icon pack supports numbers of popular launcher such as nova launcher, evie launcher and many more. Follow these steps to apply
1. Open iOS Lines - Neon Icon Pack App
2. Navigate to Apply Icon Pack Screen
3. The app shows a list of launcher that are supported such as nova launcher, evie launcher etc. Select the nova launcher installed on your phone to apply icons from this icon pack.
4. The app will automatically applies the icons from this icon pack for nova launcher.
Note: If launcher doesn't show while applying from the icon pack. Please try applying from the launcher itself.
Sony Xperia Home Launcher does not appear in this application, but it can apply this icon pack with different settings.
The setting for Sony Xperia :
1. Long press on the main screen
2. open the settings
3. Scroll down and open the appearance icon setting
4. choose iOS Lines - Neon Icon Pack icon pack
5. done, your Sony Xperia has applied iOS Lines - Neon Icon Pack.
Note: Icon pack only Support on Sony Xperia Home Launcher 10.0.A.0.8 Or Up.
Supported Launcher:
Icon Pack for Nova Launcher
Icon Pack for Apex Launcher
Icon Pack for ADW Launcher
Icon Pack for ABC Launcher
Icon Pack for Evie Launcher
Icon Pack for Solo Launcher
Icon Pack for Next Launcher
Icon Pack for Holo Launcher
Icon Pack for Lucid Launcher
Icon Pack for M Launcher
Icon Pack for N Launcher
Icon Pack for Arrow Launcher
Icon Pack for Action Launcher
Icon Pack for Sony Xperia Home Launcher
Icon Pack for Aviate Launcher
Icon Pack for KK Launcher
Icon Pack for Nine Launcher
Icon Pack for Blur Launcher
Icon Pack for Trebuchet Launcher
Icon Pack for Unicon Launcher
Icon Pack for Smart Launcher
Icon Pack for Go Launcher(doesn't support icon masking)
Icon Pack for Zero Launcher(doesn't support icon masking)
DISCLAIMER
You may need a 3rd party launcher to apply the icon pack. If your stock launcher doesn't support icon pack, you can use apps like Awesome Icons or Unicon to change your icons without using a 3rd party launcher.
FEATURES
- 36+ HD Wallpapers
- Alternate icons
- Icon Request
