28,-Kč
Popis: Představujeme projektový papír AKA Papercons jako novou variantu rodiny Material Icon Pack.
https://play.google.com/store/apps/details?id=com.fsdev.paperconsKód: Vybrat vše
https://www.uploadship.com/30fb8b5a728e2c4a
https://dropapk.to/ir5sxva2ccyf
https://upload.ac/2ptv5csd613p
https://uploadrar.com/q6kh8vzdx1z4
https://webshare.cz/#/file/1RP5ms4ss1/papercons-v4-0-p-apkWhats New:
200+ new icons have been added
Now with over 3k+ Icons!!!
THE SETUP - ( Manual Configuration Recommended )
We make your life easy as our icon pack has its own unique default icon choice. But for your personal touch, we recommend having a dive through our 4k+ icons to design your perfect Home Screen setup.
WIDGETS:
Zooper Widget:
Flat Material Zooper, Mnml Zooper, fox Zooper.
HOW NEW IS NEW
Papercons has 4800+ icons at this moment of time but with constant updating your phone will experience the pleasure of new icons and HD icons on a regular basis. Which we can assure you this will happen.
FEATURES:
- An icon pack with 4800+ icons with regular updates (constantly growing)
- New icon pack willing to change for users needs
- Wallpapers included
- Material icons are included
- Fast and easy icon request
LAUNCHER SUPPORT:
- All Popular Launchers
No Third Party Launchers No Problem:
- If you are currently on your stock launcher which does not support icon packs there is a workaround as there are many icon creators on the play store which Papercons is compatible with.
